Mikey914
Mar 28 2011, 05:43 PM
I know some of this is rehasing what has allready been said, but I needed to recap as to what I have found and what I'm doing -
Spent the morning working on this, there are 2 issues I found. I checked this on my rear and made the assumption (yes I know), that the fitment was the same.
After much closer examination I determined that the clearance on the bearing cap is not adequate it the old style bearing cap is in place. Just changing the bearing cap will not adequately solve the problem. I need additional clearance internally to make this correct. So, right now I'm working on making the caps for the fronts with a slot large enough to accomidate the bearing cap with the dimples and to give it the required depth. Attached are pictures showing the desired result. Right now I have metal comming in tomorrow to start production on replacement front caps. It will take about 3 days to process these and about 7 days to get through finishing. In roughly 2 weeks I can have these out and I will provide a prepaid postage in the package to return these
It is my intent to provide the correct fitting caps to those that want these or I will take returns and refund the original purchase price and shipipng. As I processed this through the website I will be contacting those that had stepped up later this evening directly from the email contact info provided.
I apoligize for the inconvienience this has created and should have been more through in the initial Q.C. I will do whatever it takes to make this right for everyone that put thier trust in me and my products.
Sincerely,
Mark
AKA Mikey 914
Mikey914
Mar 28 2011, 05:46 PM
And for those of you that may notice the old cap laying by the installed part I did replace with the new cap (without nipple ), to prove that it was the nipples that it was getting caught on.
richardmosselman
Mar 28 2011, 10:23 PM
Hi. I'd like a set of the caps as well as few other things from your site but I'm having trouble registering my Canadian address. It won't accept the Province or Postal Code. Hope that you can help? Cheers, Richard
montoya 73 2.0
Mar 28 2011, 10:31 PM
Do you have four extra grease caps? Since I forgot I didn't have any on the car! Crap.
Mikey914
Mar 29 2011, 12:31 AM
QUOTE(richardmosselman @ Mar 28 2011, 09:23 PM)
Thanks Richard,
I can get you taken care of. I stopped accepting any more orders on the caps for now as I need to make the orders I shipped right first. I'll PM you.
-Mark
anderssj
Mar 29 2011, 12:19 PM
Does anyone know if the grease cap interference issue also applies to the early Pedrini wheels? My wheels are a few hundred miles away and I'm unable to check . . . .
Many thanks!
Steve A-
eric9144
Mar 30 2011, 09:31 PM
Late to the thread, but any more sets still available? I'm interested if there are...
Mikey914
Mar 30 2011, 10:20 PM
Yes and no to the buy being open.
No - I'm correcting an interference problem with the front wheel and the grease caps. The Normal grease caps have nipples on them that cause the caps to not seat fully as they bind. I'm in the process of making a correct fitting part. I have the dimmensions finalized and just got material in and it's being blanked for processing. I've got a buddy working on it for me over the weekend I'll be polishing these and getting them to anodizing Tuesday, it will be roughtly 7 days before they are ready and I'll pick up and ship.
Yes I will extend the group buy as I shut it down as soon as I saw the problem. If you are interested I'll PM you from your posting on the thread if you want in. Other wise I'll just post as soon as they are ready here.
Thaks to all for your patience.
-mark
detoxcowboy
Mar 30 2011, 11:26 PM
Mark, The Front Caps are ill fitting on the isp west polished set too (your competitor in this center cap market> Just wanted to note that your may be the first aftermarket center cap maker to address this issue.. Your a pro and worth the wait and special attention.. plus the isp west site taller and do not have your excellent appearnce and anodizing
The only aftermarket caps I ever had that fit pefrect were the $350 set with the porsche center crest.. I sold them.. Waiting for your.. Joe
JRust
Mar 30 2011, 11:39 PM
No problem Mark! You are moving quick man. We all appreciatte everything your are doing in reproducing parts for our cars. I'll get the 2 sent back when the replacements come. My car isn't on the road yet anyway
mcbrems
Apr 1 2011, 11:33 AM
Ackkk. Just got my Fuchs 4-lugs back from soda blasting, tested the center cap on one of my wheels, and the fit is loose by several mils. Here's a shot of the wheels I have (before blasting):
http://914electric.files.wordpress.com/2010/05/wheels.jpg
914Mike
Apr 1 2011, 12:52 PM
QUOTE(anderssj @ Mar 29 2011, 11:19 AM)
Many thanks!
Steve A-
My Pedrinis and Fuchs are substantially the same. Fuch measured 30mm, Pedrini measured 30.3mm. This is from the wheel mounting surface to the hubcap mounting surface. Mine are early -00 Pedrinis, so YMMV... Also Fuchs have the hubcap recessed a few mm, Pedrinis do not. Someone could have polished the Pedrinis even thinner, but that's impossible with Fuchs.
anderssj
Apr 2 2011, 09:20 PM
QUOTE(Mike914 @ Apr 1 2011, 02:52 PM)
Many thanks!
Steve A-
Thanks for the reply! I've got the early Pedrinis too. There still in the original finish, so your measurements should be correct for mine too.
For Mark--thanks for the good work on this--no hurry here as the wheels are 200 miles away in NC. The caps look nice just sitting on the shelf!
Thanks again,
Steve A-
rwilner
Apr 8 2011, 04:44 PM
Mark
Just curious -- any update on this? The back wheels look so good, my front wheels are jealous.
Mikey914
Apr 8 2011, 05:30 PM
I got the first 1/2 done on these and got them to finishing. With a little bribery I've been told that they will be ready sometime on Monday. The other 1/2 will be done hopefully to exchange for the finished ones. I plan to start the exchange for the ones allready out there Tuesday.
I will be able to confirm availability on Monday, but I anticipate that I'll have these taken care of and have the 2nd half available to ship on the 18th.
Would have been sooner, but lost a drive on the lathe and had to have it replaced.
-Mark
montoya 73 2.0
Apr 8 2011, 08:22 PM
Hey Mark, I don't need replacements. I will just use the original ones for the rear and the corrected caps for the front. Now I will have a extra set just in case (I love just in cases) I lose one or some little bastard ruins one while trying to steal them.
Mikey914
Apr 13 2011, 12:22 AM
Great news -
Jot alll the caps out today from the orders that were placed on the website.
If you can simply exchange the new front ones with a pair that you recieved allready. I have included a address lable you can put over the one on the package you recieved, and postage inside the envelope, so you should easily be able to swap it out and drop in your mailbox. You will probably want to tape it back up, but if you open carefully, you can reuse the padded envelope it was shipped to you in.
Thanks all for your patience. I have another run out of the machine shop today and will be dropping them at finishing tomorrow. So I will actually be able to get more out. I plan to open up the group buy again as soon as I have a commotment from my finisher as to when I will have these in hand.
-Mark
MikeM
Apr 13 2011, 12:45 PM
Thanks for the update Mark...I'll have to start watching my mailbox!!!
Mike
mcbrems
Apr 13 2011, 12:51 PM
QUOTE(MikeM @ Apr 13 2011, 11:45 AM)
Mike
I sent this a week ago with a couple questions:
Hey Mark,
- Do you sell the airbox upper edge weather seal separately?
- Regarding the Rubber bumper to keep trunk from hitting deck lid,
you mention a metal angle bracket that must be used. How do I
get or fabricate one, and where and how is it mounted?
- I bought a couple of these guys: 914 Rubber roof holders - set of 2 left and right
and the right side was nice and rubbery and flexible, while the left side
was hard and stiff, and immediately sheared when I tried to put my
targa top in the trunk.
Thanks,
MarkB
Mikey914
Apr 15 2011, 09:44 AM
Shipped out replacements to all that bought throug the website (most everyone). I have a few that bought direcly that I'm sorting through my PMs and emails for, but if you did please drop me a PM so I can exchange.
These should be showing up any day now and I'll be opening the group buy back up as soon as I get more back from finishing (this next week).
-Mark
detoxcowboy
Apr 19 2011, 04:29 PM
Mark, I am still waiting on the Original Order for the set of 5.. Just a heads UP..
cantley914
Apr 19 2011, 04:46 PM
Hey,
Any more available?
I would be in for a set!
Steph
Mikey914
Apr 19 2011, 07:36 PM
I've got caught up on these and have machined the correct clearance to cover the grease caps in the front.
These are now available again!
Thanks to all for your patience.
I have extended the group buy til 5/15
http://shop.914rubber.com/product.sc?produ...p;categoryId=-1
Joe Owensby
Apr 19 2011, 09:22 PM
Got my last two last week. They fit great and look great. The returns are in the mail back to you. Thanks again. Joe
eric9144
Apr 20 2011, 09:02 AM
Order placed!
eric9144
Apr 26 2011, 05:44 PM
Received the caps in the mail the other day, they are absolutely AMAZING...they make the my old factory ones look like they are the after market because the new ones are that good!
THANK YOU MARK!
Mikey914
Apr 28 2011, 12:58 PM
Thanks guys. I would shure love to have some pictures installed, as my wheels have yet to be refinished and I would like to see what they look like on other than 4 lug fuchs.
Thanks to all for your support.
-mark
cantley914
May 5 2011, 08:43 PM
Got mine today in the mail all the way up in Qc.
Excellent packaging. Undamaged and fast.
They're awesome.
Thanks Mikey! A+++
eric9144
May 23 2011, 08:55 AM
914Mike
May 23 2011, 11:53 AM
QUOTE(Mikey914 @ Apr 28 2011, 11:58 AM)
-mark
Here's one of my Pedrini's with my one lonely cap. (Waiting on 7 more, so I end up with 4 for the Fuchs, 4 for the Pedrini's.)
Niklas
Jun 8 2011, 10:03 AM
Hello!
Got my caps today!
Perfect! Superfinish!!!
Niklas
VaccaRabite
Jun 8 2011, 11:07 AM
Did my replacement caps ever get mailed? My old and busted caps look old and busted, but I don't want to do the swap until I can do all 4.
Zach
Mikey914
Jun 8 2011, 11:47 PM
Nope, my fault, I missed you they'll be on the way out the door tomorrow.
Sorry about that Zack.
