URY914
Sep 25 2004, 07:50 PM
Primed and in the sun
URY914
Sep 25 2004, 07:51 PM
Nice FAT rubber. 225/50's
URY914
Sep 25 2004, 07:53 PM
I've got 1/2" spacers on the rear and about 1/4" between the fender and the tire.
URY914
from the top
URY914
Sep 25 2004, 07:54 PM
Today.
URY914
Sep 25 2004, 08:02 PM
Let do the left side, shall we...
Mark out the cut line.
URY914
Sep 25 2004, 08:03 PM
Grind/sand away the bondo...I mean paint so to get a good bond with the glass.
URY914
Sep 25 2004, 08:04 PM
Looking to the front.
URY914
Sep 25 2004, 08:05 PM
Fitting in the glass mat strips. you can see them laying on top.
URY914
Sep 25 2004, 08:07 PM
Here it is with the glass bonded over the flare and the fender.
URY914
Sep 25 2004, 08:09 PM
Out baking it the sunshine.This must have been between the hurricanes.
BTW, that's my helper on the left.
URY914
Sep 25 2004, 09:06 PM
I've actually sanded/bondo'd/primed the left rear now. I'll post some tomorrow.
URY914
Oct 2 2004, 08:42 PM
QUOTE(URY914 @ Sep 25 2004, 07:06 PM)
OK, maybe I didn't post the next day. But there was a f---- HURRICANE pounding us.
Now back on track. Tommorrow I have an autox so I've spent the week tighting up some loose ends. Here is what it looks like.
URY914
Oct 2 2004, 08:44 PM
I've got 1/2" spacers on the rear wheels and I can just get my finger between the tire and the inside of the fender. Maybe 1/2" clear.
URY914
Oct 2 2004, 08:45 PM
These were shot after loading on the trailer.
But you knew that.
URY914
Oct 2 2004, 08:47 PM
I use to run my tie down straps through the wheels but now with the solid wheels I'm having to run the straps around the tranny mounts. Not the best but it is easy to get them on and off. I dont think it will hurt anything.
URY914
Oct 2 2004, 08:48 PM
HERE IT IS.....
URY914
Oct 2 2004, 08:50 PM
I'll get some pics tomorrow at the event with the hood on. If you look close you'll see my front turn signal covers I've made. They are .0002 grams lighter than the stock ones.
Paul
Trekkor
Oct 2 2004, 11:34 PM
Those pics make me VERY HAPPY!
KT
redshift
Oct 3 2004, 12:15 AM
You are an animal.
You should scratch-build a '67 vette.
M
bob91403
Oct 3 2004, 02:42 AM
Looks nice. Looks like a lot of work. I'm too lazy. I would have spent the $675 and bought whole fiberglass front fenders, and fiberglass rear rocker panels with the flares already there. Then sold the original metal to someone who needed them for repairs. Probably end up spending the same kind of money, not near as much work. Might even be less money. I think I saw a replacement metal fender priced at about $400. But, like I said I'm lazy.
McMark
Oct 3 2004, 03:04 AM
Is this fender held on with Red RTV?
ChrisFoley
Oct 3 2004, 05:00 AM
That's looking real good Paul!
You need to lower it another inch and a half though.
Raised rear pickup points and raised spindles ought to do the trick.
Good luck at the auto-x today!
URY914
Oct 3 2004, 06:32 PM
Chris,
I agree, needs to be lower.
Low, lean, wide and mean.
Paul
Root_Werks
Oct 4 2004, 11:07 AM
You are a fiberglass animal! I wish I had you around when I was doing my flares. They look great!
URY914
Oct 4 2004, 07:23 PM
Here are some shots from the autox yesterday.
URY914
Oct 4 2004, 07:24 PM
money shot
URY914
Oct 4 2004, 07:28 PM
my new avatar
bob91403
Oct 4 2004, 08:46 PM
Looks great. A lot of work.
maf914
Oct 5 2004, 07:30 AM
Paul,
Way to go! Good work. Thanks for all of the photos.
So, are you going to paint it again or are you just gonna do the JP primer thing?
Remember, paint equals weight.
MJHanna
Oct 5 2004, 08:22 AM
Paul great work !!!
What type of resin are you using? Do you get it from an auto supply house or is it the Generic stuff you can get at Home Depot? On tying down the car we made some brackets out of some flat metal and drilled a hole to mount them to the lowers shock bolt and a hole to put the tow hook through. Made it easy to hook the back tie down straps.
URY914
Oct 5 2004, 08:50 AM
I got the resin from a fiberglass supply house locally.
I've seen those "hook-eyes" but I thought there wasn't enough room for them on the bolt. The shock bolt is short and nut just covers the trhreads now.
Show us a picture.
Paul
