Great progress Yesterday, NO pics
Picked up the engine, got it into the garage. Started to dress the engine with the D-jet. Got all the vacume hosees on, fuel lines (ran out of high pressure hose ) got the alternator hooked up, runners, intake, dual pressure sender.
Had a question on the sender. It is a metal hose that sticks up and the end of the hose has a small coupler then the sender threads to that. The question is, why is there almost 1/4 inch gap when the sender is threaded all the way till it is tight. Is that normal? I used a tiny amount od red gasket maker on the thread. is that good?
next question
I am missing the decel valve, and I remember that it is not necessary. What is the correct way to bypass this, connect the two larger vacume hoses togeather and plug the smaller hose that come off the intake?
next question
I can find the firing order but i forget if the distributor spins clockwise or counterclockwise I dont want to get the plug wires wrong
Next question
What gauge wires to run for the oil pressure sender to the gauge and same thing from the fuel pressure sender to the gauge up front?
last question
Do I use a sealent when putting the sensor on the bung from the tail pipe, if so what type. This is for the oxygen sensor
More questions to come.
I am very very close
