To continue this interesting discussion, why is it (in the original post) that you think the location for the GT-spec air exit under the front of the car is non-ideal, TC? It seems ideal to me.
My logic is that the airflow near the front of the car underneath should draw the air out through that vent by the Bernoulli principle. Put another way, that principle tells us that a pressure differential must exist across the vent below the car when there is perpendicular fluid flow.
I suppose the case could be made that the flow under the car is likely rather turbulent, but if the vent is installed close enough to the front there shouldn't really be that much turbulence there. Even if a vortex developed under the car (which I
think would give it noticeable lift characteristics on the front which I'd not heard of happening with the 914 at reasonable high speeds [i.e. below 140 mph]), it would still be such that fluid flow is perpendicular to the vent itself regardless of direction, going forward or backward relative to the vent. Hence, it's still Bernoulli principle, and still a "suction" or more correctly a pressure differential that pulls flow out through the vent. I have to add that at high speeds having a suction underneath the vent might be a moot point given the driving force across a front-mounted oil cooler being dominant.
The principle would work anywhere there is such flow characteristics, even near the back of the car (without having to have the special-case NACA duct). The problem with having a cooler further away from the front is the obvious loss of fluid flow across the cooler itself that one gets in the front of the car (assuming the car is moving of course).
Just thinkin' out loud.
Sidebar: I have a small point to consider about the difference between an oil cooler and an intercooler: in one case, the air is removing heat from oil and in the other it is removing heat from compressed air. Obviously the type of material the cooling fins and tubes are made of is a big factor, but the point remains that one is removing heat from oil and the other is from compressed air. A brief search confirmed my suspicion that the specific heat capacity of most common oils (likely to be higher for motor oils) is about twice that of air under STP. When air is compressed it's c(p) as well as it's thermal conductivity will go up a bit. What I mean is that air is much more effective at removing heat from compressed air than oil, all other heat transfer parameters being equal. In other words, there may be more more important factors in installing intercoolers (such as length and complexity of plumbing and distance from the compressor impeller and the intake manifold) vs. the same for moving oil around. I would wager its cheaper and more effective to route longer oil lines than longer intercooler lines, so oil up front and intercooler near the motor seems to be the way to go, by my logic.
Ye gods, I'm glad I typed all that before the cold meds really took effect.
