914itis
Sep 30 2012, 08:36 PM
What was wrong with the suspension? ... You need to derive it to Hershey .
Sep 30 2012, 08:47 PM
QUOTE(914itis @ Sep 30 2012, 10:36 PM)
Needs typical rust repair. But so do I.
You need to drive it to Hershey . - I agree. Driving it the 9 miles to work in the mean time.
mittelmotor
Sep 30 2012, 09:31 PM
QUOTE(mepstein @ Sep 30 2012, 07:30 PM)
Car is back on the road with new bushings on the shifter and trans linkage, new mc and hard and soft lines on the brakes and a new chts. I procrastinated on the sensor since I was told it was a difficult job. Decided to hide the sensor wire in a long socket and changed the sensor in 2 minutes. (after removing FI parts). - And lowered the front end. Love driving it!
Looks great with the steelies.
When I first got my car, I was tempted to go that route, though I would've had them widened to 7".
Oct 18 2012, 10:04 AM
The more I drive it, the better it runs.
okieflyr
Oct 18 2012, 04:52 PM
QUOTE(mepstein @ Oct 18 2012, 12:04 PM)
By the time you and the car make down to the ECC it should be a supercar!
Oct 18 2012, 08:01 PM
QUOTE(okieflyr @ Oct 18 2012, 06:52 PM)
Umm, about that... umm...
BajaXJ92
Oct 18 2012, 08:33 PM
QUOTE(mepstein @ Oct 18 2012, 10:01 PM)
Damnit Mark, bring the car down!!
Dec 15 2012, 08:44 PM
Car has been taunting me with it's occasional rough running. Changed the fuel filter today. Tightened the hose clamp a little extra once the new fuel filter was on and the clamp blew up on me. Gas ran down my arm and stunk up the garage. Wife was pissed.
Found some barrel nut clamps at autozone to hold the heater wire on the heater flapper boxes. $2 for 1/2 dozen. Holes needed to be drilled out a bit to hold the solid end of the cable but the brass was easy to drill out bigger.
Didn't finish the job since the driver side cable tube is slightly corroded and wouldn't let the cable snake through. Going to put some larger cable on a drill to try and clean it out a bit. Can't wait to have heat!
Made up my mind to get a mid rise lift.
Dec 20 2012, 08:32 PM
Hooked up all the parts to get heat into the cabin. Everything works but the fan. Even without the fan, heat is nice.
Still running poorly at times
914itis
Dec 20 2012, 09:08 PM
Same thing 2 weeks ago, and after reading the bible, I noticed that the realay was missing. It is the last relay facing the rear of the car. If you stand by the wheel well net to the relay box , I think it is the lay one to the right.
Dec 20 2012, 10:21 PM
QUOTE(914itis @ Dec 20 2012, 10:08 PM)
Did yours alternate between running well and poor? That's whats killing me. Running great, park it and an hour later it's a bucking bronco.
914itis
Dec 20 2012, 10:25 PM
No, mine runs perfectly fine. I was referring to the blower motor.
Dec 20 2012, 10:27 PM
QUOTE(914itis @ Dec 20 2012, 11:25 PM)
That makes sense. I will check - Thanks!
Dec 21 2012, 10:28 AM
QUOTE(mepstein @ Dec 20 2012, 11:27 PM)
Checked - Relay is in place.
sfrenck
Dec 21 2012, 11:06 AM
QUOTE(mepstein @ Dec 21 2012, 11:28 AM)
Switch it with another relay - may be bad.
914itis
Dec 21 2012, 11:26 AM
Switch with headlight relay and make sure the ground wire is connected under the red pull lever.
Mar 3 2013, 09:30 PM
Pulled the engine
Mar 3 2013, 09:35 PM
The hell hole/engine shelf have seen better days. Someone tried to build a new one with copper plate, expanding foam and undercoating.
914itis
Mar 3 2013, 10:16 PM
Wow ! What's your plan for this one?
Mar 14 2013, 10:38 AM
My wife always complained about the gas smell from this car so while I had easy access the the fuel lines, I stripped all the old lines and prepped for stainless and new hose. As you can see from pic 2, the old braided lines had seen better days. They tore off with very little pressure. Also found that when the PO had redone the gas tank (good), he kinked the overflow hose and let the end sit inside the gas bulkhead (bad).
Mar 14 2013, 10:56 AM
QUOTE(914itis @ Mar 4 2013, 12:16 AM)
Hell hole is the only problem area that I can see on the car. I'll eventually have Scotty B do the proper repair and repaint back to orange.
hot_shoe914
Mar 17 2013, 10:35 AM
Here you go Mark, another red one. Suppoedly a barn find with 47K miles on it. I will be going to check it out in about an hour. I know how you love the red ones.
http://memphis.craigslist.org/cto/3686109698.html
914itis
Mar 17 2013, 10:53 AM
The listing price should be $1500 less just for that spoiler .
Mar 17 2013, 10:57 AM
QUOTE(hot_shoe914 @ Mar 17 2013, 12:35 PM)
http://memphis.craigslist.org/cto/3686109698.htmlMine is 36K and much better condition.
I promised my wife no more 914's until I get this one and the one at Scotty B's running. She likes 914's, but doesn't like non running cars.
hot_shoe914
Mar 17 2013, 11:09 AM
QUOTE(mepstein @ Mar 17 2013, 11:57 AM)
http://memphis.craigslist.org/cto/3686109698.htmlMine was 1/2 the price, 36K and much better condition.
This one runs and drives. Once he sees my 2500.00 barn find (Betsy) I will hopefully have his price thinking in a much more realistic state of mind.
hot_shoe914
Mar 17 2013, 03:17 PM
Okay Mark, you are safe. This was a respray and appears it was originally Olympic blue. Won't get into details but I think it is a 200-400 dollar parts car. Agood project car on the east coast, scrap on the west coast.
Yes, I DID get the vin# 4732922048
Mar 17 2013, 04:42 PM
I'm hoping to get this on the road for hershey. It's nothing like the pristine cars that other world members are bringing but it makes me smile when I drive it.
Mar 17 2013, 04:47 PM
QUOTE(hot_shoe914 @ Mar 17 2013, 05:17 PM)
I think the current owner realized they bought a junker and are trying to unload it. It's not that hard to make a type 4 engine run but that doesn't mean much in the big picture.
Apr 15 2013, 12:29 PM
Dropped engine
New fuel lines - rubber and SS
Vacuum hoses
Manifold seals
Injectors cleaned and new seals
Fuel filter
Changed oil
Changed trans fluid
New injector elbows
Alternator belt
OEM muffler to replace Bursch
Odds & ends
Reinstalled engine
Crossing fingers that it starts and runs without the previous hesitation.
914itis
Apr 15 2013, 12:32 PM
Good luck, ...... I am standing by for the results.
Apr 15 2013, 12:35 PM
I was ready to start it last night but realized the insurance had lapsed and I'm not turning the key until I have confirmation it is reinstated.
Apr 16 2013, 09:07 AM
Drove it around the block last night. Engine is sounding good. OEM muffler sounds good. Didn't have a problem with engine hesitation. I hope that problem is solved.
Wife commented that the garage didn't smell like gas - priceless!
The headlight issue is new so that's next on the list.
Jul 17 2013, 07:18 PM
Thinking about a marriage...
914itis
Jul 17 2013, 07:22 PM
Snowing in PA?
Jul 17 2013, 07:35 PM
to get a good price, you always want to go after the ads that have been around forever, not the ones that are new with unrealistic prices. this one has a salvage title which will help bring down the price.
Jul 17 2013, 07:42 PM
I want what's inside the metal wrapper.
Heat, air, modern, cheap. and a matching 5 speed manual trans.
914itis
Jul 17 2013, 08:26 PM
Looks like the feever is moving east.
okieflyr
Jul 18 2013, 05:57 PM
Looks like fun
Beware: It is a slippery slope........
Jul 18 2013, 07:18 PM
QUOTE(okieflyr @ Jul 18 2013, 07:57 PM)
Looks like fun
I want a car that can take a real road trip.
hot_shoe914
Jul 18 2013, 08:03 PM
QUOTE(mepstein @ Jul 18 2013, 08:18 PM)
Looks like fun
Buy Betsy!
Jul 18 2013, 08:17 PM
Road trip, not off-road trip
Already did the carbs thing and I want a/c.
okieflyr
Jul 18 2013, 08:54 PM
I hear ya, A/C for my car has been getting well recieved by the wife👍👍
Feb 23 2014, 09:22 PM
Decided to keep this car all original so now it's time to fix a couple things before Hershey. At one time, mice had lived above the fuse panel and though they didn't chew any wires, the panel is pretty ugly with rust and corrosion. Bought a spare from Garold so I can make the switch one wire at a time. Garold's sold me a nice part but I wanted all the contact points to be clean. I poured some white vinager into a Tupperware container (don't tell my wife) and dropped the fuse holder in. One hour later I rinsed and dried. It's exactly what I wanted.
Mar 8 2014, 10:30 AM
After the cheap paint job done years ago, the trim was installed half assed. I pulled the rear trunk lock out that had been glued into the body with construction adhesive. The lock cam was broken and a small machine screw inserted to trip the lock. I found an old lock and rebuilt it with the lock mech from the car. Ordered a new inner seal and cam from Tweet.
Mar 8 2014, 03:53 PM
I switched over the fuse panel but the headlights still don't work. Originally they stopped retracting down once up, then the lights stopped working. I replaced the headlight switch. Still no lights but they will go up and I can dim the lights in the gauge cluster. The fogs do work if the headlight switch is on. Any ideas?
orthobiz
Mar 8 2014, 08:54 PM
QUOTE(Tom_T @ Feb 27 2012, 02:40 PM)
When I was in HS or College I would've died if my Dad bought/gave me a 914!
... of course they were new then, Dad wasn't rich & I was a struggling student working my way through college - ergo a 3 year old used 73 2L a year+ out of school was the best I could swing!
I had a 2000 dollar budget in 1975, bought my 1971 Signal Orange 1.7 and have been hooked since then.
Paul
Apr 20 2014, 11:32 AM
Got the proper bolts for the Fuchs and made the switch. The car sits 3/4" lower and handles great.
Aug 30 2014, 09:55 AM
Cleaned up the Fuchs. Not new but not bad for a 40 year old wheel.
Aug 30 2014, 10:05 AM
Now
Sep 15 2014, 12:35 PM
My wife thought I paid for a personalized/vanity tag. I didn't. It was just luck of the drawl that I got this one
