QUOTE(cwpeden @ Mar 14 2012, 07:33 PM)
Ditto, If anything he will need to use more shim to make up for lost material..
Less shim, not more.
The end play shims go between the flywheel and main bearing thrust surface.
The machining done to remove the gouges moved the flywheel closer to the bearing.
The flywheel moved forward by the amount of material removed, thus the possible need to shim the clutch fork ball - same as if the flywheel was resurfaced.
Like Dr Evil said.
Tony at Translog will take care of the end play shims. Joe needs to determine if the clutch fork ball needs an extra washer.
