QUOTE(Eric_Shea @ Aug 17 2012, 06:41 AM)
The Yield Strength of aluminum will always be the same regardless of the "caliper design". Now, let's get into real world observations: I've "NEVER" seen a broken aluminum caliper but I've seen "innumerable" steel calipers with mounting ears fractured off and sealing flanges fractured. Steel is much more brittle than aluminum. The aforementioned Brembos have been in use since the mid-70's and again, I've "never" seen one broken or fractured. Same material depth on the mounting ears and around the piston flanges. Again, an aluminum copy of an ATE steel caliper that was used on virtually every European make sedan and sports car. Finally, virtually all modern calipers are all made of aluminum now as it's lighter and stronger and better suited for the application of being hung off a cars suspension. They're using computers now and... they're using aluminum to manufacture calipers. Some "slide rule" designs were ahead of their time (Porsche seems to be famous for this).
If you want to play armchair engineer, which aluminim alloy are you using. Blanket statements like "steel is much more brittle than alumimum" show that you haven't worked with many different aluminum alloys. Try bending 6061-T6 and see how it does? There is a lot of work that goes into alloying a metal and picking the correct one for the application.
Brembo, Alcon, PFC, Wilwood, etc all spend huge amounts of resources on trying to make their calipers stiffer.
Back it up. Can you tell me how you could possibly know these companies spend huge amounts of resources to make their calipers stiffer or is this a general claim? If I were to make a general claim it would be that their engineers look at the numbers I posted because modern design practices dictate the use of the "Yield Strength" figures.
I've spent probably 10 hours talking to brake caliper engineers from Wilwood, PFC, and Alcon about the merrits of different designs and caliper flex and strength. Or, if you would like, PFC will tell you at
http://www.performancefriction.com/motorsp...e-calipers.aspx. Notice the number of times they tell you the calipers are forged and have gone through FEA analysis. Also notice that most new aluminum calipers have either a bridge bolt or an acutal part of the caliper body cross the pad area to hold the two halves from spreading.
All the brake companies will tell you the flex is in the caliper design, not the fasteners.
Again, back it up. You've spoken to "All the brake companies"? I've searched for your "flex design" criteria. I think you're making general statements that people could easily confuse with facts and even those are wrong. E.G.: with 4 M8 fasteners running from the nose to back... the fasteners "definitely" do play a factor in flex or no flex. If the fasteners were made out of rubber; would the caliper flex? Aluminum? Now steel? Steel is used where it is needed in modern computer designed aluminum calipers.
Most of the flex comes in the caliper material and design. Does some come from the fasterner? Sure. Is it the majority? No. Notice most new hi-pefrormance calipers are forged out of special alloys. They are also
designed [i]to be made out of alimunim, not steel.
So Matt... are you worried about actual "Strength" or are you concerned that these will literally "Flex" their way off the car? Or is there another point that you feel needs to be made?
Neither. Will they be strong enough? Probably, but I don't know. Will the flex themselves off the car? Probably not, but I don't know. Do you? Did you test them? Do the engineering? After all, brakes aren't that imporotant.
Maybe I wasn't clear in my original posts - will these flex and cause pedal feel problems? What will they do when they get hot? I'm sure you've come across the stories how the aluminum 911S calipers can be really spongy compared to the steel calipers. Wonder why?
Also, if you would like to make attacks, I'm happy to talk to you about being an "internet racer." I'm happy to put my track experience up against anyone on this site. What's you're track experience? Or better, what's your engineering background?
