QUOTE(JamesM @ Dec 4 2020, 03:28 AM)
QUOTE(Frank S @ Dec 3 2020, 10:43 AM)
I haven't used the cam you are using, but I think your Idle is under advanced. I think it should be around 13 to 14° BTDC.
In the VE Table I would adjust all the cells around idle to the same value.
If you can't use the AFR reading, just go for the lowest MAP value you can reach by playing with fueling and ingnition settings but disable closed loop idle at that time.
At idle I would say ignore the AFR readings even if you do have them, always tune idle to the lowest MAP reading. AFRs at idle are good for a point of reference but for the best idle you want to aim for the lowest MAP regardless. Dont try and tune to a specific AFR target there, let the engine tell you what it wants.
I find most type 4s i have tuned with megasquirt wind up being happy around 12 degrees advance at idle AFRs i have seen anywhere from the low 12s to the high 13s/low 14s depending on the motor.
With properly setup fuel and ignition tables closed loop idle control is unnecessary. Its cool to have, but not necessary and could be masking other issues.
Guys, this is very good information, but I do have a couple of questions for clarification if you would be so kind as to entertain:
1. I have heard you all talk about tuning idle to lowest possible MAP. It looks like both
@Michelj13 and I, with our Raby cams perhaps, have real difficulty idling below 70 kpa. Having said that, I guess you have to FIRST pick a target idle RPM, right, and then tune the fuel cells in the area of the VE table there for lowest MAP, correct? I mean, I get a much lower MAP when I pump more fuel/air into it, but then I'm idling more around 1200 to 1400. Yes, my AFR idle numbers are useless.
You need to ask Jake for what idle RPM the cam was designed.
At higher RPM you'll allways get lower MAP reading
If you change IGN timing or fueling you need also to adjust "air" to keep the desired RPM.
Just try something inbetween 1000 and 1050 RPM (just guessing)2. In terms of timing, I have always heard that Type 4's like the 12-14 degrees BTDC, but I also seem to hear that in closed loop settings it's good to set the ignition table in the idle range to something significantly lower than that so the idle advance settings have "room to advance" for adding RPM. Is that fair?
That's fair but you don't need to add or pull so many degrees in timing. When I check your log, you are running between 4 and 6° Advance during idle...
As always, I appreciate the insight. I've attached my current tune and a 10-minute, fairly boring datalog of my cruise today just so Michelj13 can see it. It idled pretty well in CL and ran well, although I think I'm lean in spots. At some point I was running so rich that I think I'm erring on the side of lean now.
Michelj13, like you I have a little trouble with the first start of the day. I can't get the tune to where it fires right up, stays running without any pedal feathering, and the RPM climbs to a healthy 1200 or more. In my case it may initially stall after catching, and then the second time with a little pedal it'll gain some heat / momentum. At that point, with CLT in the 70 degree range or so, it will stay running but with an anemic idle in the 600 to 700 range. Once CLT hits about 85 or 90 it starts getting much more stable and strong.
You are actually pulling RPM/Air at low temps in your MSQ.
I meant to do a datalog of a cold start this morning, but forgot. How often do you do that? Take your laptop out to the garage with some new variables changed all ready to gather some good data. Upload the tune and fire it up without starting a datalog
10-Minute Cruise with some idling at the end:
Click to view attachmentMy current tune:
