JFJ914
Feb 12 2013, 10:25 AM
QUOTE(Gint @ Feb 11 2013, 07:30 PM)
Got mine installed late yesterday. Ball sockets that actually pop off. I still need to synch and remove the crossbar plate from the top of the carbs. But synching should be a lot easier.
Did yours have the built in return spring?
McMark
Feb 12 2013, 10:32 AM
I emailed Gunter again to see what's up. I just looked again at the CSP site and perhaps it's compatible with
this spring which is an add on option.
Hopefully I will hear back from Gunter soon and we can see about ordering the spring for those who want them.
biosurfer1
Feb 12 2013, 01:45 PM
Count me in for a spring
Gint
Feb 14 2013, 10:00 AM
QUOTE(John Jentz @ Feb 12 2013, 09:25 AM)
No. Just the carb springs at this point. I don't think I want a return spring. I prefer a nice light throttle. I haven't really driven it yet though either.
Gint
Feb 17 2013, 09:50 PM
That works great! What an improvement over those stupid cross bar linkages.
Harpo
Feb 18 2013, 07:49 PM
Please add me to the list for the additional return spring
Thanks
DAvid
billh1963
Feb 20 2013, 06:53 AM
Didn't look closely at mine....I also thought these were going to have the built in return spring. Put me down for a spring.
Gint
Feb 20 2013, 07:00 AM
I'm not using a spring other than what's on the carb shafts. Works great!
DBCooper
Feb 20 2013, 07:30 AM
Unless there's something wrong with your carburetors you shouldn't need an additional return spring. That linkage is so low friction that it doesn't "add" anything. That's not to say you don't need a spring, I don't know, but if you do you might want to take a look at your throttle cable, or your carb's throttle shafts.
Gint
Feb 21 2013, 06:58 AM
Or at least get it installed first!
You don't know that you don't need a return spring unless you've tried it.
JFJ914
Apr 9 2013, 09:25 AM
Any news about the spring?????
ConeDodger
Apr 9 2013, 03:36 PM
QUOTE(John Jentz @ Apr 9 2013, 07:25 AM)
Yes, and it's good news too! It's Spring!
McMark
Apr 11 2013, 12:21 AM
I've tried several times to get info from CSP about the return spring. The bottom line is that I haven't gotten any word that there is a spring made
specifically for our setup. The T1 spring may work, but I won't have time to do any research into this aspect.
B2524
Apr 13 2013, 09:58 AM
Are any of these still available, I missed this thread. Thanks,
Kd
rmital
Apr 27 2013, 11:18 AM
QUOTE(McMark @ Sep 5 2012, 05:21 PM)
I'm ordering a few CSP Bellcrank linkages and I figured I'd put it out as a group buy and offer a discount, as well as a package deal with the throttle cable bracket I make.
This is the best, easiest to use/install linkage available. I've used a ton of them and the build quality is outstanding and installation is dead-simple. I'm also including the throttle cable bracket that I designed specifically for this setup. That means this a complete setup for dual IDF users.
Original price for the linkage from CSP is $155 (at current exchange rates)
Original price for the throttle bracket is $35
Total retail is $190.
Group buy price: $165. Closes 12/18/2012
Order NowI will place the order with CSP on 12/18. The setups will ship from Germany to me, and then I'll reship to you. Expected shipping is the week of 1/10/2013.
I installed the linkage, very nice....and the bracket....the barrel of the accelerator cable is past the connection point (cable too long)?
anyone have this issue? did this last night, finished up around midnight, so going to take another look when I get home today; but certainly seems the accel cable is just too long.....
McMark
Apr 27 2013, 02:39 PM
There is a ball-socket at the pedal. This should be threaded all the way on. If not it can cause the problem you're looking at.
And while you've got your head in the pedal cluster, make sure the throttle stop isn't bent and allowing the throttle to return farther than normal. And inspect the throttle arm at the cluster to make sure the rod isn't bending. The arm to rod should be 90 degrees/ right-angle.
LotusJoe
Jul 25 2013, 08:18 PM
Is this setup still available?
Dtjaden
Jul 25 2013, 08:49 PM
Can anyone compare this to the Tangerine cable linkage (ignoring the price difference)?
ConeDodger
Jul 25 2013, 09:57 PM
The CSP is crazy good. I can't speak for the Tangerine though Chris pretty much universally makes great product...
McMark
Jul 25 2013, 11:19 PM
I think I have a couple, send me a PM.
r_towle
Jul 26 2013, 02:16 PM
QUOTE(McMark @ Apr 11 2013, 02:21 AM)
Post a pic of the spring if this is still a problem.
We had good success with MSC or McMaster Carr when we needed springs, they have all springs...
Looks like (from what pictures I see here) the spring would be part of the bell crank, so its a torsion spring.
They have a hug section of these at the two HW vendors above...
We order ten different ones for a robot once, kept trying them till we found the right tension for the application...
They were pretty cheap.
rich
JFG
Oct 10 2017, 12:36 PM
Does anyone have pictures of the carbs where the csp plates fit? I can't tell which one they're calling left or right and the images in the instructions are blackened photocopies
nditiz1
Oct 10 2017, 01:04 PM
QUOTE(JFG @ Oct 10 2017, 10:36 AM)
McMark made a pretty good video showing the setup. Look for his vid here. I believe you are wondering about the rods. They attach to the carb plates. They are very similar to the hex bar setup you had on there.
http://www.914world.com/bbs2/index.php?showtopic=317510
JFG
Oct 10 2017, 01:39 PM
I'll watch that video in full tomorrow.
My confusion is the instructions refer to right/left carbs and the throttle plates provided in the kit replaces one of them?
Have users connected them to the standard plates that come with the carbs?
IronHillRestorations
Oct 10 2017, 05:50 PM
QUOTE(JFG @ Oct 10 2017, 11:39 AM)
You have to put an adapter on each one. When you have the parts in front of you, you can see it's simple and very straight forward
simonjb
Aug 31 2018, 08:59 AM
Help, but which Carb is left and which is right? I am installing and trying to following the instructions. Thanks !
