So like the old TV shows often had what we have here is a crossover episode.
Now this next move may not win me a lot of popularity but I also have a 911.
That being said this motor I am building for my 914 is in California as is my 911.
I want to put it into my 914 but i don't have a front oil cooler for it yet or the fuel system needed to feed the motor. I do own the fuel system but i have done an admirable job failing to install it.
The bad news is my 911 has been consuming a large quantity of oil after a rebuild.
If anyone has any interest in the story all of that information is in the build thread below. I feel like I somewhat outgrew the thread title fairly quickly but I am stuck with it now.
https://forums.pelicanparts.com/porsche-911...-questions.htmlMy tentative plan was to remove my 911 motor and tear it down and put my 914 motor into the car in order to break it in, tune it and verify everything is good to go before I stuff it into the 914 chassis.
Click to view attachmentSo that's what I did over this Christmas break. Clearly this motor started its life being placed into a 911 chassis so its not the end of the world that its going back into one. however I'm not sure I want it to be used to being backwards from the proper orientation.
Click to view attachmentThings to note, I did refurbish the fan but I found out quickly that not all alternators and fan rings have the same offset or depth, so i have a mismatched fan in there in order to maintain the 911 alternator with the chassis. I did not want to rewire for a temporary (we will see how long that lasts) situation.
And I also decided to re use the spark plug wires but the orientation had made it somewhat messy due to the order being changed a bit. Thinking about this I probably could have solved it but I was in a hurry.
The motor now has only about 160 miles on it but its better than nothing.
I do have a 914-6 engine mount that welds in I bought from McMark years ago, however due to the spec of the motor I have some pause about if its the appropriate mount based on the power output of this 2.8.
with this motor in the 911 its certainly healthy and pushes the car along with authority.
I was considering buying a mad dog mount for its wider stance. I wanted to skip anything that was a solid mount or near solid since I do plan on driving the car frequently once its all together. I did when it was a 4 so i dont see any reason for that to change with a 6 cyl.
So, what I am saying is I would not mind hearing opinions about this situation I have gotten myself into.
