Today I replaced the dash bulbs with LEDs, since it is so hard to read the gauges at night.
The bulbs, designation BA7s-W, can be obtained from superbrightleds.com
http://www.superbrightleds.com/cat/ba9s-ba7s/A few tips for other newbies:
1. Take out the screws that hold the cluster face plate and pull out the plate. But, you won't be able to pull it out far enough because of the speedometer cable. So, lift the cable off of the clip in the footwell. This will give enough "play" in the cable to let you pull out the face plate far enough to access the back of the gauges.
2. Push each gauge out of the faceplate from behind.
3. OK, a total newbie error, but might as well pass it on... to get the old bulb out, push in and turn. Sheesh, busted the first bulb trying to pull it straight out. Duh!
4. The metal bulb housings ground to the gauge cases, so once you replace a bulb you need to hold the bulb housing against the gauge case to test it.
5. Do not drop a bulb into the housing by accident, or you will have to disconnect everything to get it back out. (Ask how I know)
6. Those spade connectors are brittle. One of them broke, so I had to splice in a new female side.
7. DO NOT Replace the alternator bulb with LED!!!. Your alternator will quit charging. Has something to do with how the current goes through the bulb.
Went for a drive tonight to see what difference it made. For the speedometer, makes a very significant improvement. Definitely worth it. For the tachometer, the left side is much brighter. Right side is still pretty dark. I'm wondering if one of the LEDs isn't working, so will take it apart again and check. Left gauge... parking brake warning light is much brighter. Fuel guage is still nearly unreadable at night (I think that has one of the tiny bulbs that is not the type that can be replaced with LED... I forgot..
Here's some pics and two videos. The first shows the OEM turn signal bulb, and the second shows it replaced with an LED.
https://www.youtube.com/watch?v=fSvEb_r7BXohttps://www.youtube.com/watch?v=5IphOdeOVTc
