What keeps the fuel from dripping on its own on these carbs? I mean the mixture screw is at the bottom of the carb and the progression ports are fairly low too. Since gas is above these points what stops fuel from leaking just by way of gravity?
The idle circuit takes its fuel from the main fuel well. It then loops up higher than the float level and then comes back down to the progression ports and mixture screw. The idle air jet is at the top of the loop which breaks the siphon and stops the flow. A plugged idle air jet won't break the siphon and fuel will continue to flow until the float bowl is empty. Your idle mixture will also be super rich.
To clean it, remove the idle jet on the offending cylinder and blow from the vent (idle air jet) down. You'll easily see when it's clean. If there's crud, make sure to get it out so it doesn't plug up the idle circuit. You can stick something in there as long as it doesn't booger up the hole. Get that whole circuit super clean.
Thanks for the breakdown. That is super helpful to me because I am a very visual person and since I can't see what is going on inside the carbs I can't understand it exactly. I'm assuming that vacuum pulls the fuel through this system when operating correctly?
You know, I actually have done the above a few times and when I do it sprays carb cleaner through the idle circuit very cleanly and with good pressure so I'll have to step it up and stick something through the hole. Any ideas what to use? I asse I need something strong but thin.
