Oct 29 2014, 09:22 AM
One reason I bought on Amazon is their reurn policy. If this turned out to be less than I expected, they would go back. Right now, I have no thoughts about returning them. They have met all my expectations.
StratPlayer
Oct 29 2014, 09:41 AM
Those will be my next upgrade.
FourBlades
Oct 29 2014, 11:14 AM
I think the hids George installed are about as bright. I think the hids throw a more even light pattern. There are some brighter and dimmer areas with the led that the hids don't have.
The leds are awesome because they are a 15 minute install with no modifications. The super sharp cut off is also very cool.
John
JmuRiz
Oct 29 2014, 12:40 PM
Very neat upgrade, I have 65w H4s in my car, but may think about these...especially when/if I get my car done and want to drive it to events that last to the evening.
Anyone have a volt-meter in their car...if so, how is the volt drop with these headlights vs standard?
Thanks,
Chris914n6
Oct 29 2014, 04:01 PM
QUOTE(mepstein @ Oct 29 2014, 04:09 AM)
QUOTE(Chris914n6 @ Oct 29 2014, 12:12 AM)
If I did my calculations right, that GE LED is twice as bright as a 35w HID. That's insane.
It also should get super hot. I'd look into it as cutting some air vents in the surround might be in order.
Why would it get super hot? Draws less current and led run cool. I put my hand on the bulb after a couple minutes and felt no heat at all. I'll run them on my way to work today and check again.
LEDs at this level get hot. From the pics it looks like the whole rear housing is a ribbed heatsink. The majority of vehicles using this style headlamp are front engine so will have turbulent air behind the unit. The 914 is relatively enclosed. Might not be a problem but it should be looked into just in case. Heat kills electronics.
Even 60w equivalent house light bulbs have built in heatsinks.
Testing during the day will give you a better idea of heat buildup during summer nights.
Chris914n6
Oct 29 2014, 04:16 PM
QUOTE(JmuRiz @ Oct 29 2014, 11:40 AM)
Amazon...
Q: How much power do these draw on High? on Low?
A: According to ge tech specks... The lights draw 1.8 amps on low beam and 3.6 amps on high beams.
I might have used the wrong formula...
GElighting website...
How many Watts are these (LED Headlamps)?
The GE LED Headlamps produces a similar amount of light to 55 watt halogen product however, because LEDs are more efficient, the LED Headlamp uses less power.
sfrenck
Oct 31 2014, 08:31 AM
Is there a silver band with "GE" across the middle of these or not? I see pics both ways:
From Grassroots Motorsports (on a Miata.... sorry):
Click to view attachmentGrassroots Nighthawk reviewFrom Amazon:
Click to view attachment No silver band seems much more presentable to me.
Harpo
Oct 31 2014, 09:28 AM
The ones without the GE might be trucklites
Oct 31 2014, 10:38 AM
Might matter to me on a 911. On my 14, the lights are either on or down.
sfrenck
Oct 31 2014, 10:49 AM
QUOTE(mepstein @ Oct 31 2014, 12:38 PM)
So yours have the bands?
Oct 31 2014, 12:51 PM
QUOTE(sfrenck @ Oct 31 2014, 12:49 PM)
Yes. The band on mine is chrome/mirror, not silver. There has to be some sort of divider since low beam is only the top half of the bulb. The bottom half stays dark until you turn on the high beams. The low beams project the amount of high quality light you would expect on a modern car. The high beams are amazing but make the low beams look dark after you shut the highs down. But there's no way to drive towards another car with the highs. They are blinding.
Harpo
Oct 31 2014, 05:13 PM
I just ordered a pair. Looks promising
David
jaywood
Nov 5 2014, 03:52 PM
Where are you guys buying these from? Amazon?
Nov 5 2014, 04:39 PM
QUOTE(jaywood @ Nov 5 2014, 04:52 PM)
Yes. $165/each
Java2570
Nov 5 2014, 04:54 PM
I'd be interested in seeing a photo of the light pattern of these LED's, how they compare to H4's.
JmuRiz
Nov 5 2014, 08:37 PM
bandjoey
Nov 6 2014, 01:58 PM
How Do They Do Thay???
My email today from Amazon listed 7 different LED 7" headlights for sale. Next the drone will deliver them with a mechanic to put them in.
I'm interested but they did not know it was me looking.
Nov 6 2014, 02:17 PM
QUOTE(bandjoey @ Nov 6 2014, 11:58 AM)
Oh yes, they did.
They use cross-domain cookie exchanges to track your browsing habits across multiple websites.
That's how facebook knows that i looked at newegg for a new graphics card and then facebook starts feeding me ads related to the card models i viewed over there.
Basically, different websites are exchanging your browsing history with each other to generate a more or less complete map of your browsing habits.
This has been happening for a long time ...
Chris Pincetich
Nov 6 2014, 02:46 PM
OMG this is cool. With the time change, I am driving very dark, windy roads alot. PLEASE keep posting about install tips and whether or not leaving them on for 1+ hours causes heat buildup.
Thanks!
With the 914 World crew we could maybe organize a GROUP BUY on these. Especially if a vendor could get wholesale price. I'd buy them today if the price were comparable to my H4s.
Nov 6 2014, 04:09 PM
QUOTE(Chris Pincetich @ Nov 6 2014, 03:46 PM)
Thanks!
$165 seems bargain basement for right now. In time I'm sure they will be less. I don't feel any heat from the bulb after a half hour of night driving. Installation takes 5 to 10 minutes per side with one Phillips screwdriver.
Harpo
Nov 6 2014, 05:17 PM
Has anyone seen any interference issues? Does anyone have a 75 or 76? It may be an adjustment issue but The face of the headlight was dragging on the inside.
Thanks
David
Chris914n6
Nov 6 2014, 10:52 PM
bandjoey
Nov 11 2014, 10:10 PM
After the install and driving for a few days....update and results. Are they worth the money? Final verdict on heat and some street pictures? Thanks.
Nov 11 2014, 10:15 PM
QUOTE(bandjoey @ Nov 11 2014, 11:10 PM)
Drove home at night at least a half dozen times. My opinion hasn't changed. I will never go back to standard bulbs. But now I am ready to get Spoke's led taillight upgrade.
mikesmith
Nov 12 2014, 09:30 PM
QUOTE(mepstein @ Nov 11 2014, 08:15 PM)
And his front lights. They're Very Niceā¢.
Chris Pincetich
Nov 24 2014, 12:10 AM
The install was easy, but I did forget to get the extra wire and connector tucked up and behind the light. It hung down, then jammed when closing, but was OK. All set now! I included a photo below of the connector hanging down - don't do that!
I should have a chance for some night driving soon. So far, they look much brighter that H4s while in the driveway at dusk
Click to view attachmentClick to view attachmentClick to view attachment
Krieger
Nov 24 2014, 12:31 AM
Chris, give us your opinions of night driving with those new bulbs. You had H-4s before with 55 or 100?
Krieger
Nov 24 2014, 12:32 AM
How do they compare?
MJHanna
Nov 24 2014, 07:07 AM
Did Amazon bump the price up or just for me?
http://www.amazon.com/GE-NIGHTHAWK-Round-R...p/dp/B00BQX2BT8 it list them at $290.65 -100.00 coupon+= 190.65 not 165.00
gryphon68
Nov 24 2014, 08:17 AM
QUOTE(MJHanna @ Nov 24 2014, 08:07 AM)
Amazon tends to fluctuate prices based on available stock, could be they are running low. Not unusual to see price bump drop back down when they get more stock in.
Chris914n6
Nov 24 2014, 03:06 PM
Heat is not a problem. The SEMA displays were on half a day when I got there. The rear housing is one big aluminum heatsink.
The replacement bulbs wouldn't fit so it's mute.
dale73914
Nov 24 2014, 05:16 PM
After driving mine all through winter here iin Australia, i have been folloowing this with much interest.
Thinking i now know what Santa is bringing.....
Nov 24 2014, 05:43 PM
It's a great upgrade and would take 5 minutes to reverse if you needed to. I'm really glad you guys let me In on this product.
Chris Pincetich
Jan 12 2015, 08:12 PM
After driving with these for about a month I can say this is an awesome upgrade!
The light is super bright compared to my not very old 55W H-4s, which were way brighter than OEM set-up that was in there 10 years ago. They are worth adjusting, as the light spread improved when I aimed them up a bit. I added a link to the reviews on Amazon - a lot is written. I was happy to read that I am not the only one to notice the bright "X" formed in the middle of the road by the somewhat angular hot-spots in the pattern of light
Overall, bright, WIDE, white light 2-4x brighter than standard options and the install is plug-n-play. I was constantly "over driving" my old lights during PM forays on the local twisty forest roads, but now can see way ahead and much farther around corners as I cruise at 55mph
I can't comment on the high beams. Mine don't work
Need to fix that, but less important now w these new headlights.
http://www.amazon.com/GE-NIGHTHAWK-Round-R...yRankDescending
FourBlades
Jan 12 2015, 09:32 PM
Still loving mine.
I look forward to driving at night now...
John
Jan 12 2015, 09:39 PM
QUOTE(Chris Pincetich @ Jan 12 2015, 09:12 PM)
http://www.amazon.com/GE-NIGHTHAWK-Round-R...yRankDescendingYou need to fix your high beams. They are too bright to use around traffic but light up like the sun on an empty road. If both your highs are out, it might be your car and not the lights.
Chris Pincetich
Jan 12 2015, 10:18 PM
Yup, it's not the new headlights. I have the Jwest flasher, Jwest fuse assembly, and a "newer" wiper stalk assembly, so all of that wiring has been messed with and I obviously didn't put something together correctly. I've replaced the relay, added that "jumper" to it, and still I can't get the little blue light or "click" to indicate the high beams should be working....
mobymutt
Jan 13 2015, 07:17 PM
Those headlights are amazing! Can we get them at a discount in bulk?? Group buy!
db9146
Feb 25 2015, 08:36 PM
Any other source or coupon known for these?
infraredcalvin
Feb 26 2015, 08:42 AM
QUOTE(db9146 @ Feb 25 2015, 06:36 PM)
rmdinmd
May 25 2015, 06:40 AM
just ordered mine. Amazon has the $100 off coupon which brings the price with shipping to just under $200 each. I placed two seperate orders for 1 each to use the coupon for each order. It says you can't do that but it seems to let you.
Cairo94507
May 25 2015, 06:48 AM
Yup- that is how I bought mine too.
May 25 2015, 07:45 AM
QUOTE(Cairo94507 @ May 25 2015, 08:48 AM)
me 2. I can't imagine that you won't be very happy with the lights. I sometimes use mine as daytime running lights since I know the lifespan is multiples of normal lights.
SKL1
May 26 2015, 10:53 AM
I'm in the process of doing the relay wiring with the jwest kit for my new H4's and now I see this thread!!
Can I assume you don't need the relay set up with these lights as they don't draw a big current?? That would sure simplify things...
Cairo94507
May 26 2015, 11:21 AM
That is correct. Just remove the old and plug in the new.
SKL1
May 26 2015, 11:45 AM
just ordered with my wife's prime acct. did 2 orders and both took the coupon. It just asked me if I wanted a duplicate order as I did them both back to back. anxious to try them out! probably will end up with them on both cars!!
dangerranger01
May 27 2015, 09:29 PM
These are awesome.
My lights should arrive tomorrow....is there any difference between left and right hand sides? Couldn't find much info.
Regardless, this upgrade is going to be amazing!
dangerranger01
Jun 10 2015, 08:58 PM
Excuse my newbness, but is there a way to leave the headlights up and not have any lights stay on? I can only get them to stay up and have the running lights stay on. Tried a bunch of different combos of key and switch positions but couldn't figure it out....or is my wiring jacked up?
zambezi
Jun 10 2015, 09:35 PM
yes, pull the round relay by the light motor, then turn off the lights
dangerranger01
Jun 10 2015, 09:45 PM
^^thanks. Does that relay control the motor or the bulb, or both?
never mind...found it in my wiring diagram. it is only for the motor.
