QUOTE(J P Stein @ Dec 3 2014, 11:02 AM)
QUOTE(Randal @ Dec 3 2014, 08:22 AM)
A video on an iphone takes about 2 seconds, maybe two clicks is all. Don't they have iphones up there in God's Country?
Sure, they got enough of them to tie up every fool in the country.
My cell is talk & text only.....I mostly ignore texts & don't send any.
Ok, I'm a luddite, so shoot me, but you better not miss. I do embrace certain technologies.
Merry Christmas JP and speaking of Christmas, here is an early Christmas present to myself.
Re-plumbed the oil lines removing the Mocal thermostat that ran to the front oil cooler.
Ha, just saved 30lbs (no front cooler/lines/oil) and did so at no dollars. So a pretty good weight reduction for the buck, hey? For the stuff I run I don't really need the front cooler and THANKS to Bill for the suggestion.
Now have to buy an Accusump and they are pricy.
Here is an after picture:
Click to view attachmentHere is before:
Click to view attachmentNow I've plumbed the new Accusump, putting it into the drivers compartment where I can turn it off and on, so using the manual valve. Also used the AeroQuip hose and push on fittings. I will be adding clamps, although I probably don't need them. Also cut a 4 x 4 in square out of an old IMSA slick, cut a 2" hole in the middle and will rivet that to keep the hose centered in the hole. KISS as JP would say.
And from the back side.
Now ready to fill the Accusump, put oil back into the car, pre-oil the bearings and start her up.
