QUOTE(lsintampa @ Dec 30 2014, 09:52 AM)
At this point - it seems I may be near normal.
I reset the dwell and timing. I'm not sure why timing should be set with the car at or near 3,000 RPM? It's been my experience over the years to set timing at idle.
Thinking about that, it would be next to impossible to do, when at idle, the surging was nuts.
Anyway, with the help from my wife to jack the rpm's up to around 2500 - 3000, I set the timing. Ended up retarding the advance quite a bit from where it was.
That seemed to drop my idle way down to under 900 RPM - and the surging seems to be near gone.
I don't want to say it's resolved - it would be nice to know for sure if the timing may have been another part of the issue. (along with the leaking cold start valve).
I can FORCE the surging by doing one of two things.
1) advancing the distributor a lot
2) at idle muck with the throttle plate switch - take it off it's idle setting
Anyway, there have been times with I "thought" it was right - just to let it sit for a while and watch it go nuts on me.
Will test again later today. Keeping fingers crossed - that maybe it's settled down?
Timing is set at 3500 rpms to guarantee you are setting the timing with full advance on which at that speed is purely based upon centrifugal force and not vacuum.
Its a unique way of timing, and if you use a zip tie you can easily pull the throttle to the right speed and set the timing accurately.
Now, when you change the timing by ear, or by hand, you WILL screw things up.
So, STOP doing it. its not right and it will certainly create an issue.
Go back, set the timing by the book.
I know you changed it again, so go back and reset it properly.
Then, and only then will things sort out.
1) set Dwell
2) set timing at 3200 rpms steady, not blipped (watch for variation in timing when the rpms are steady, that will define a new issue....if it wont hold steady)
3) turn the ECU knob to full rich
4) set the TPS to the only correct spot it can be set....(again, its not a tuning aid and its not adjustable...stop messing with it)
If you do all of these things, you are now setup properly.
See if that works.
If it is close and idle moves a little bit let me know.
If the timing mark moves while you are watching it with the light at 3200 rpms, let me know.
You need to stop messing with three things at once.
Set them all properly so this can be diagnosed and fixed.
Proper diagnosis involves changing one single parameter at a time, not two or three.
you stated
Number one, yup, so set it right
number 2, yup, so set it right.
Rich
