Finally an update for my lean running condition...
I've been working on this issue on an off since I got it back on the road . I'm finally getting to the bottom of it. The root cause of all my issues? VACUUM LEAKS!
I sprayed starting fluid throughout the engine bay and I found nearly every connection leak air. I was quite surprised since I was diligent putting the motor back together with new gaskets, sealant, etc. Intake tubes to heads... leaked. Intake tubes to plenum... leaks. Cold start valve... leaked. Temperature sensor II... leaked.
Here's a good shot of the leak at the cold start valve. New gasket and even some sealant, and it still had a nice hole for air to get in.
Click to view attachmentAfter fixing all these areas the running condition improved but I was still experiencing issues. At this point I would say the issue was 75% contained. Spraying fluid around the plenum and throttle body still caused the idle to shoot up. I swapped out the throttle body and again I saw a slight improvement but still had issues. I came to the conclusion that plenum itself was leaking at the seam. I swapped out the plenum and saw an improvement but still had issues. I would say at this point issue was at 90%.
So at this point I assumed that the replacement plenum also leaked so I welded up the original plenum and low and behold the running issue once again improved and it runs very close to normal. Lets say 95%. This is currently where I'm at. I took it for a short drive today and I didn't have time to see if there are any more leaks.
