Can't believe it's been so long since my last post. Busy fall and winter, got work on the car done incrementally. Time to catch y'all up... I guess I knew this at one point, but after cutting all the rust out of the driver's side long, I realized I was going to be fabbing more than I did on the other side. I suppose that's why I started this project in the first place.
So after removing the engine support and suspension pylon, then peeling back the rusted layers, I figured I would build a buck and hammer form the "elbow" shape where the long comes out of the wheel well and turns horizontal...
Click to view attachmentI thought I would impress everyone with a gif of me forming this part. The gif turned out good, but the part is no bueno.
Click to view attachmentHere's the final - not usable. In the end, I just made the part as a straight channel section, then slitted it and bent as needed. Slits get welded shut. A couple transition pieces will be cut to fit and added for the final attachment to the horizontal part of the long.
