as posted on the update thread :::
OCTOBER UPDATE: for BACK IN BLACK(i'm renaming my thread this with the addition of the AC/DC song of same name as my official music) yep, that's all I've done-----
no, actually what I have accomplished is hooked up wiring, put in new fuel lines, fuel filter, pump, tank etc.
I bought the car as a rolling stripped down project, so normally I would not have done that but with this contest its not a bad way to go. it saved me a lot of time and trouble, but as discussed on Jeff B's recent tread asking the question which is worth more or which would you prefer, its a hard thing to sort thru all that stuff done by someone else, so I have spent hours sorting thru bags of labeled stuff, and some not labeled, digging into the car to look for rust(of which I have found some, nothing show stopping) and assembling a list of stuff I need to order from restoration design.
-began chipping out the tar board in the floor pans, found some rust along the edges of the floor, but mostly just surface stuff so far. right hell hole had a bad attempt at previous repair, including bad welding and calk!,
-wiring: wow what a mess - this takes the most time. Ordered some schematics, a member here sent me a PDF which I blew up, sent to local print shop, had them printed and laminated so I don't need my glasses to read them!!
- pulled wiring back thru to sort, hook up the fuel pump. because I need to know what I have in order to know if I am doing major or minor engine work- i'm really close to trying to crank it up so that I can then check for leaks, check compression etc. ( car is a 75 with 1.8 L-jet.)
- what I have sourced and ordered so far:
1. new Mahle wheels from member here: - will be shipped today or tomorrow(soon as I pay him
2. New Distributor with installed optical points from Hot Spark - I read here that several others were using this distributor and very happy with the performance.
3. ordered vac hose, bought pump, filter and gas line and hooked all that up
4. new battery
5. I bought 914rubber.com bumper tops for back dating the bumpers- this might not happen, as I was contemplating a full stock build and restore: which poses the question, should I or should I not? because I cant find a set of decent nice chrome bumpers!!! , SO for anyone out there that might have a set let me know, otherwise it will have to just sell these toppers, and put the stock stuff back on (which maybe I should do)
this car is a mostly clean it up, make repairs and reassemble mostly in a stock fashion. Not custom.
Goals for this month that I believe I will have met:
- rewire , sort thru that- test run motor, strip floor pan and assess all areas for rust
- order parts, source proper wheels for car, sort thru parts stash,
- sourced a local Porsche shop that will help with next months goals:
-start car, run it and asses motor for needed repairs before dropping it out and cleaning it up
-threw out almost all interior parts except seats!! it was all trash
** so new list of parts needed to go forward: hell hole repair, battery tray, new dash and all new interior including door panels, back pad panels, white vinyl for back , doors, seats, - need to find out what carpet the car would have had stock- it was originally a stock black outside and white interior???
Next months goals: minor welding repairs of rear firewall, hell hole, replace battery tray to original location, fix 2 other body rust spots, prime etc
- pull motor and clean, put all nice new stuff on it,
- maybe finish minor body work have either touched up, or full respray- this is not decided yet.
- * will need all new exhaust so that decision will come later, but, I have very nice 1.8 heat exchangers with triad exhaust on my 75 2.0 copper car, so I might do a swap and buy the dual outlet SS. set up from Tangerine racing and put it on the Copper car. Decisions, Decisions!!!
Pictures will be posted on my thread, but yea, we've made some progress!
major parts orders are coming from 914 rubber, PMB, Restoration Design and Auto Atlanta.
