Mikey914
Oct 30 2015, 07:27 AM
It's the 1.8 elbow that has multiple fittings If there is enough interest I'll make these.
Who needs one?
davesprinkle
Oct 30 2015, 07:43 AM
I'm in.
(Also, my buddy with an L-jet transporter needs one. But I'm not sure if it's the same part for that application.)
ChrisFoley
Oct 30 2015, 08:26 AM
Make it and they will come.
Chris H.
Oct 30 2015, 10:53 AM
Don't have my 1.8 any more or I would be all over this. A lot of people don't realize theirs is cracked. All it takes is a hair line and your idle is screwy. For $45 just CHANGE IT.
pete000
Oct 30 2015, 10:55 AM
Mine has a loose breather fitting, I would be in for one !
echocanyons
Oct 30 2015, 11:01 AM
I'm in for one
timothy_nd28
Oct 30 2015, 01:15 PM
I strongly urge all Ljet owners to buy one of these! This is typical the source of tiny nuisance vacuum leaks.
RohJay
Oct 30 2015, 01:16 PM
Count me in Mark. Thanks
Mueller
Oct 30 2015, 04:21 PM
Someone in another thread mentioned there is a difference between the part for MY74 and MY75?
If so, you'd want to make sure it fits both year models.
catsltd
Oct 30 2015, 06:07 PM
Ill take one also.
If you cant get enuff people charge more.
Some of us really need one,and are willing to pay for one.
Cheers
2ma2
Oct 30 2015, 06:15 PM
I'll Take one also
Mikey914
Oct 30 2015, 06:21 PM
The part number I'm looking at is 022.129.967T The P is for the 1.7, so these for 1.8 are all the same from what I can see. I would be very surprised that for such a short run they made changes. Anyone have a different part number of theirs?
Paging Brad Mayer
Jett
Oct 30 2015, 06:59 PM
I'll take one
JB620
Oct 30 2015, 07:04 PM
Count me in too please. Thanks Mark
75914-L20C
Oct 30 2015, 07:27 PM
Cool! I was about to suggest that you reproduce this part! This, plus a $1000 2.0L rebuild kit. (J/K
I have 2 styles of the intake elbow here. 022.129.967T has a larger (~24mm) upper fitting hole and the 022.129.967 (no T) has a smaller (~16mm) fitting hole. I have the 022.129.967T on my '75 1.8L. I don't know what uses the non-T part.
I am definitely in for the 022.129.967T with the larger upper fitting.
- Pete
022.129.967T above, 022.129.967 below
Oct 30 2015, 07:35 PM
orthobiz
Oct 30 2015, 08:14 PM
QUOTE(Mikey914 @ Oct 30 2015, 08:21 PM)
Paging Brad Mayer
He's in South Africa for vacation.
Paul
orthobiz
Oct 30 2015, 08:19 PM
I am in for two!
Paul
orthobiz
Nov 1 2015, 09:28 AM
QUOTE(75914-L20C @ Oct 30 2015, 08:27 PM)
- Pete
Click to view attachmentIs it possible the picture on the bottom has the right metal tube fitting in place and despite the different part numbers, they really are the same? Looks like that picture may be perfectly looking down the barrel of the metal fitting...
Paul
Porschef
Nov 1 2015, 10:12 AM
I don't know if these are even available as OEM anymore, but like our dashes, I'd think even if they were, they'd be a crackin' in a short time.
For 45 bucks? I'm in
davesprinkle
Nov 1 2015, 10:38 AM
Paul
No. This is not an optical illusion. I can confirm there are two different elbows. They differ in the diameter of that port. The large port version is from '75 & '76. The small port version is '74. I used a large-port version on my '74, but had to get a fitting manufactured to step down the diameter so that my vent line would fit.
914fahrer
Nov 1 2015, 11:04 AM
If it is possible to send it to Germany. I`m in for one
Mikey914
Nov 1 2015, 01:08 PM
Shipping to Germany is not a problem.
I can make both versions. Not too much difference. Good to know applications. Just need a few more to make this viable.
Mark
orthobiz
Nov 1 2015, 06:14 PM
QUOTE(davesprinkle @ Nov 1 2015, 11:38 AM)
Paul
Thanks. The metal tube fitting near the TOP side on mine is 22mm, same size as the oil filler breather.
Paul
Grump
Nov 1 2015, 06:36 PM
I placed a WTB elbow hose for my 75 1.8. A member sent me one, and it's the one on the right. My old elbow is on the left.
The part number with the T suffix, is for a 74 which he sent me. Without the T is for a 75.
As you can see the "Y" fitting has to fit in the large hole. The "T" hose hole isn't big enough.
Bill
75914-L20C
Nov 1 2015, 08:08 PM
QUOTE(orthobiz @ Nov 1 2015, 09:28 AM)
Paul
No, there is no fitting in place, it is just the bare elbow.
- Pete
bobh
Nov 1 2015, 10:35 PM
QUOTE(Mikey914 @ Oct 30 2015, 08:27 AM)
Who needs one?
Still excited about receiving my new dash. Might as well double the excitement. I'm good for one. I think it's great that you are reproducing much needed parts. A big Thank You! for all you do.
DRPHIL914
Nov 1 2015, 10:38 PM
Mark I will take one as well for my build challenge car.
bretth
Nov 2 2015, 07:11 AM
Awesome. I need one for my 1975 1.8 please. You rock.
Brett
bdstone914
Nov 2 2015, 07:52 AM
QUOTE(Mueller @ Oct 30 2015, 04:21 PM)
74 and 75 are different. One of the plug in pipes is a different size. The mold should be msde for the larger size and a reducer insert used for the snaller size.
Bruce
Mikey914
Nov 2 2015, 09:38 PM
QUOTE(bdstone914 @ Nov 2 2015, 05:52 AM)
Bruce
Exactly my plan.
DenjaCol
Nov 2 2015, 11:30 PM
Sounds good, count me in too. Mine looks okay but the metal fitting does twist pretty easy. I have a 1974 1.8 with the 22 mm fitting at the top, BTW is that 22mm hose available? Anywhere??
pete000
Nov 3 2015, 12:29 AM
QUOTE(DenjaCol @ Nov 2 2015, 10:30 PM)
I was just trying to find this. Not even listed in the Porsche PET catalog.
Mine is OEM cloth covered and it is really hard as a rock. I have seen lots of make shift replacements, but noting nice as the stock formed hose so far.
ClayPerrine
Nov 3 2015, 07:48 AM
I would buy 2 of them. I for use, and one for a spare.
For Betty's car.......
rdgabert
Nov 3 2015, 08:10 AM
I would take one for a '74.
Thank you for doing this,
Robert
motorvated
Nov 3 2015, 04:26 PM
Count me in for one for a '75.
914Sixer
Nov 3 2015, 08:23 PM
Could the VW bus guys use them over on theSamba ? That might be another market for the hoses.
ChrisFoley
Nov 4 2015, 07:09 PM
QUOTE(914Sixer @ Nov 3 2015, 10:23 PM)
I think there's a difference to the bus intake boots.
But there may be a similar demand.
orthobiz
Nov 11 2015, 05:20 AM
Only 38 posts means less than 50 takers (unless we all buy two)...
Paul
74ravenna
Nov 11 2015, 11:19 AM
I'll take one for my 74 1.8.
Thanks
orthobiz
Nov 15 2015, 06:04 PM
Weekly bump. Hey Mikey, how many more before you make this??
Paul
bigkensteele
Nov 15 2015, 08:42 PM
I will take one for my 75, even though I am converting to a six. I would like to see these reproduced, as I believe that L-Jet is the way to go on a four.
Mikey914
Nov 17 2015, 06:26 PM
QUOTE(orthobiz @ Nov 15 2015, 04:04 PM)
Paul
Just about there to start the drawings. I'm willing to make these as they are needed. I just need to make it pencil out.
orthobiz
Nov 19 2015, 10:38 PM
QUOTE(Mikey914 @ Nov 17 2015, 07:26 PM)
Paul
Brad Mayeur told me he would keep some on hand also. Thanks!
Paul
Mikey914
Nov 19 2015, 11:46 PM
I have started the drawings, will be about 2 weeks with the holidays.
pilothyer
Nov 23 2015, 11:44 PM
Count me in for one for the 75
alfadoc
Nov 24 2015, 12:37 PM
I'm in for my '75
johannes
Nov 25 2015, 03:03 AM
May be interrested as I ordered a used one for the same price from a forum member six month ago and was never delivered !
brooks944
Dec 2 2015, 05:58 PM
I'm also in for one for my '75 if it's not too late.
Mikey914
Dec 5 2015, 04:53 AM
Not too late. Drawing done, tooling started !!!
