Ok summary time! Dyno day: so i towed it out to speed factory. within a few minutes we were tuning the car. it was idling at an AFR of 22/1 (hecka lean) and would only even out at certain rpms. after adding alit of fuel some timing, deleting a few codes, and more it was working well! The carvwas brought to operating temp where it was discovered their was a massive air bubble (suprise, suprise) after an hour and a half and Gallons of water the angry sounding air bubbles were subdued. from their it was the money shot, the dyno tune. we strap the car down do a few adjustments and before i knew it, it was ready for its first pull. pull 1 i made 215hp and 207lbft. More adjustments followed as their was some knock from 13psi!. Second pull disaster
, at approximately 5000 rpm the cars rpm suddenly jumps and the car wont move. A few minutes of research found I broke an axel.... It wasn't even the Porsche side the Subaru side snapped at 187hp. day was not lost after i fix the axel i can actually drive it (sainly)!
