Click to view attachment Click to view attachment In and Out holes.
Click to view attachment A handy and necessary device from 100 yrs ago.
The header tanks are there only to be a place for the steam to go,the highest points.
Large flows through the header tank is not needed,merely a path for steam.
A one line header tank is also functional,as is desirable at the front.
A sight glass,or plastic tube,may be temporarily installed to determine the rate of steam accumulation.
Taking a long drive in heavy and hot conditions will stress the system,building steam in the top of the rad.
Make certain the pump and pipes system can flow the minimum LS cooling flow,~55-65+ gpm.
A decent copy of a truck's cooling system is a good start,other than the remote radiator,pump and restrictive pipes.
Build your shroud to pull air through all of the radiator,make certain the airflow at 20 mph is sufficient.
Use a manometer to check pressures fore and aft of the rad,then calculate airflow.
A checklist of changes from stock configuration will point to errors,as the design has been well flogged.
A 55 gal drum should be filled in less than 60 secs,at maximum,by the pipes and pumps used.
Running @ 2K rpm,a flow of not less than 20 gpm is necessary to cool the LS.
Reducing the diameters of the pipes will yield a smaller,and hotter flow.
Stick to the LS thermostat,setting the operating temperature,and flows.
https://www.google.ca/search?q=ls+water+pum...water+pump+flowhttps://www.google.ca/search?q=manometer+cu...anometer+customhttps://www.google.ca/webhp?sourceid=chrome...=thermodynamicshttps://www.google.ca/webhp?sourceid=chrome...al%20conductionhttps://books.google.ca/books?id=y1XuAgAAQB...ics&f=false http://ecomodder.com/forum/showthread.php/...sure-21680.html/
The Python look,to cool an LS.Anything else is just skinny,not cool.
http://www.914world.com/bbs2/index.php?sho...0844&st=723Don't agree tho,with hanging them below the floor pan,inviting torn hoses by road trash.
