this is a nice thread, Glenn!!
hurrah!
it's all uphill from here
Glenn wrote: "I was just pointing out that this car never had a Karmann badge." "from the back side you can see there were never holes to mount the badge, this is consistent with 914 043 0011"
- that is also consistent with my 0919 -
which incidentally, has no trunk stamp either (at least none i can find evidence of, tho i never stripped out the oem paint) - per Dworazik, 0919 was built on a fresh non-production shell prior to being "stamped" in the way that production line cars were done
it wold be interesting to know if 0012 has the vin tab/stamp up under the dash above the ashtray slot
( i had one six that did have it there; mine does not - same "fresh shell" reason as noted above) (it's a bitch to see it! - much less to photograph)
QUOTE(sixnotfour @ Aug 18 2016, 05:25 AM)
Glenn your forgetting on sixes the only info on the pillar badge is the paint code.. scrape away in the trunk..we want to know ########
