here you go, right out of Steves Email ...
Thanks for your interest in the Fuel Injection System.
This is a state of the art FI system.
It allows you to contrrol the fuel and timing with great precision.
It is very simple to program via Laptop
The system is comparable to the Motec system in Quality and features.
This system will give you from 20 to 30% increase in power over your existing fuel system FI or Carb.
This is due to the fuel being burned at the optimal point in the combustion process.
Stock FI or carbs are very crude in offering the optimal combustion of fuel to the engine and have no provision adjust the timing.
I am offering it in two packages to allow you to select the best setup for you needs.
The Basic package contains:
The EMS with mount tabs
Harness with 8 foot leads
Cable to interface laptop with EMS
Optical trigger
MAP Sensor 3 bar in case later on you want to turbo your engine.
Temp sensor.
CD with 50 Base maps to get you up and running.
Operating Manual .
The base package is for use with your stock Runners with Injectors and TB.
For engines 1679cc to 2056cc
This package is $1600
If you have a Larger Engine the following package will give you more power.
This package has the above items plus:
65mm TB on a modifided 2.0 Plenum with TPS sold as an exchange part
4- 24lbs fuel injectors.
Harness for 24 lbs injectors.
Fuel line runners for 24 lbs injectors.
Air Cleaner for 65mm TB.
This is $1950.
The stock 2.0 plenum and runners will work for displacments up to 2.8 liters.
Twin TB are not necessary for performance.
I have runners and plenums if you dont have any.
For more info on how this system works and the features use this link.
Take a look and you can see the benefits of this system.
Download the program to see how easy it is to program the system for your engine.
Future upgrades to the system are downloadable from the internet.
There is a Datalogger built in.
Thanks Steve
http://www.emeraldm3d.com/em_m3dk.html
www.type4parts.com
949-650-7366 9am-5pm PST 7 Days a week
Please read:
Note due to a high volume of email.
If you dont hear from me in a day or two write me again.
I get alot of email so I may not of gotten a chance to respond to yours yet.
Thank you Steve
Surf before you surf - http://www.surf.co.nz
