I forgot to add this; you may already have this update. https://www.agtengineering.com.au/product-p...Ejr4GulBgKcm7Ss
Thanks for the link. I didn't know about that canbus module. I'll do some research on it, but one question that comes to mind is if it is needed when using engine management that accommodates canbus (like Haltech and Link).
Thanks for including us on your resto journey! I'm likely going to be doing a lot of similar repairs to my 74 2.0.
Q: did you use stock aluminum windshield trim for the windshield or a rubber seal? I had a 914 awhile ago that had a rubber windshield seal and I never did figure out how it was done. I'll be replacing my cracked windshield and (hopefully) re-installing the aluminum trim, if I don't completely mangle it during removal. BTW, If anybody has any tips on how to successfully remove windshield trim, I'd appreciate it.
Regarding the flux core MIG: IIRC, I was told that flux core wire may have baked in impurities that may eventually pop out like a rust bubble later on on finished body panels. If anyone else can enlighten and/or correct me if I'm wrong, I'd appreciate it, as I'm getting ready to buy a MIG welder and want to ensure I'm getting the right type.
When I had the windshield installed, I didn't have any of the factory trim, so the installer basically create a rubber seal with windshield silicone. It works but only looks okay closeup and when I eventually do full paint, I plan to spring for new stainless trim.
Yeah, my flux core welder gets me through for this kind of work that's sort of hidden away. I do sometimes get a burst bubble effect in my welds, which could be related to contaminates in the flux core. When I get to the point when I weld on GT flares, I plan to upgrade to MIG, or even a MIG/TIG combo unit. Though I doubt I'd try to do flares for my first TIG project.
