I've been driving a 25 mile course while ringing out the cooling issues. I run the same exact course when the ambient temp is 84F. I know 98F would be better but I needed at temp I might see everyday, this time of year, in order to have a base from which to accurately compare the runs. At times this becomes boring so I kicked on my WSW to see how they were doing. Fine on low but when I switched to Hi my digital combo gage went blank.
Since I was familiar with this run and expected temps I continued home where I replaced #8 fuse and everything was back to normal. The next day while returning and close to home I kicked on the lights as it was dusk. Bingo, the little Gremlin returned. Once again the gage went blank. This time it was a 20a fuse on a remote fuse panel I added earlier to handle the fans, pump and the 2 large red wires which feed the OEM fuse panel and steering column. Those two were originally unfused. A different fuse this time but on the same circuit basically.
I disconnected ground at the battery and pulled all of the fuses as well as the 3 molex plugs on the steering column. Then I re-connected the battery and and added one fuse at a time. Nothing. I plugged the molex plugs back in and when I connected the one to the ign switch it blew another fuse. When I pulled that harness down to look for burned wires I saw the culprit's. There were small punctures on both the large red and yellow wires.
Click to view attachmentI stuck my finger where they contacted metal and could feel a couple of small sharp points that felt like slag although I couldn't see them with a mirror. I removed the spades from the plug and slipped 3 different sizes of Marine Heat Shrink over the pictured areas to serve as thick spacer so those spikes wouldn't penetrate the wire sheathing again.
Click to view attachmentClick to view attachmentI'm guessing the reason those fuses hadn't blown before was because I'd never placed a "load" on those wires but once I did it was enough draw to arch and blow the fuse.
Who knows? I'm not an electrical whiz. Anyway, that did take care of it and all systems are back to normal.
