I spent the morning grinding off layers of poorly welded, and poorly mage reinforcements on the inner of the longerons. Both sides has at least two different welders (one could weld the other, not so much. On the battery side, I removed 3 layers of patches that seems hacked on below the sheetmetal that the motor rubber seal is crimped to. Below that I found 2 more layers, several vertical indentions in the inner sheetmetal just in front of the suspension console. They looks 'factory'.
So are the longerones the same construction , right and left?
Where does the multilayer construction begin?
I can do some inspections via using a hole saw, which I need to do to clean the inside of the Longs, as they have lots of sand/grindings, and assorted debris inside.
Thanks for any help.
