Here it is mounted to the dog ear brace tube...lines ready to be crimped. Bracket is not complete as shown in the previous photos.
And do yourself a huge favor when you install these lines, use EZ Turn on the threads and surface of the sealing flare. It will prevent the whole threads staying on the thermostat, when disconnected, issues they have had over the years with this type. It also minimizes binding when the metal sealing surfaces make contact, when tightened. EZ Turn is used widely in aircraft maintenance, it is like Vaseline from hell, you can not wash it off with soap and water...it stays where you apply it. If I am worried about corrosion when I install a part, I use EZ Turn on it. Its more commonly called "Fuel Lube" among us in the aircraft maintenance world.
MB
https://www.aircraftspruce.com/catalog/cspa...CAaAmzVEALw_wcB
