Mikey914
Sep 19 2018, 11:42 PM
So, a problem part is the door pins that do wear. These can make a popping sound when the door is opened. We have machined these to be slightly larger so that they will take up some slop in the old door stay arms if you are not doing a complete rebuild. They make a very tight fit on the new arms and will not allow the pin to shift in the new arms (the old pins tend to corrode and wear over time).
So you can buy just the pins at $8 a set
These just came back from plating (note the current picture shows unplated I'll update tomorrow) and we will be kitting up starting tomorrow.
Best deal if you do on have these is the entire kit at $44. This will do both doors and includes the standard kit shown + 2 new pins.
SO Who's interested?
n2j2ryan
Sep 20 2018, 12:11 AM
Yes, Thank you. Just the pins please.
DRPHIL914
Sep 20 2018, 06:02 AM
I did this rebuild as part of my full door restoration last month but yes one of my doors is popping, so I would like to get pins only for both doors, thanks!!
Phil
914Sixer
Sep 20 2018, 07:07 AM
2 sets of pins please
Olympic 914
Sep 20 2018, 07:27 AM
1 set of the pins for me also.
I see there are no holes for cotter pins, or grooves for a snap ring clip. do the pins just drop in there and stay?
I don't have the original pins, I have bolts w/ nuts in there now. and they are too loose.
Chris H.
Sep 20 2018, 08:36 AM
I'll take a set of pins. Thank you.
markhoward
Sep 20 2018, 08:43 AM
Would like a full kit.
porsche914gt
Sep 20 2018, 08:52 AM
I need the pins please
Grafiks
Sep 20 2018, 09:01 AM
I need the full kit.
Shadowfax
Sep 20 2018, 09:15 AM
Full kit for me too, please. Thanks, Mark!
GregAmy
Sep 20 2018, 09:23 AM
Is there a "how to" on this anywhere? I bought a set a couple months ago, opened the door, looked at it, and closed the door and grabbed another beer from the fridge instead.
Mikey914
Sep 20 2018, 11:08 AM
QUOTE(Olympic 914 @ Sep 20 2018, 06:27 AM)
These are just a drop pin. Gravity and friction will work well here.
Mikey914
Sep 20 2018, 11:09 AM
QUOTE(GregAmy @ Sep 20 2018, 08:23 AM)
I'm sure we can do up something may take a week or so, but I can do that.
Mark
GregAmy
Sep 20 2018, 11:23 AM
I'm quite certain I could figure it out, just takes some motivation to get started (and beer). Knowing in advance what's involved helps with that motivation (but, sadly, not the beer).
rasam
Sep 20 2018, 11:48 AM
I'll take a full set
Andyrew
Sep 20 2018, 12:37 PM
In for Pins
ClayPerrine
Sep 20 2018, 01:12 PM
I need 6 pins please.
Clay
bbrock
Sep 20 2018, 03:21 PM
One set of pins please.
11tenths
Sep 20 2018, 05:29 PM
I need a couple pins to replace the screws that came with the car.
And BTW- If you thought the pins that attach the emergency brake cables to the rear calipers would work, think again.
-Harry
mb911
Sep 20 2018, 05:52 PM
QUOTE(11tenths @ Sep 20 2018, 03:29 PM)
-Harry
Might want a full kit..
Mike D.
Sep 20 2018, 06:15 PM
Yes please, I'll take two!
And if you could please reman these for my VW Bus that would be great too.
JK
dlee6204
Sep 20 2018, 06:23 PM
Interested in a kit
restore2seater
Sep 20 2018, 09:38 PM
I'm in for a set of pins.
whitetwinturbo
Sep 20 2018, 10:56 PM
2 pins for me
PanelBilly
Sep 20 2018, 10:59 PM
I need a set.
rob gannon
Sep 21 2018, 08:24 AM
carking1996
Sep 21 2018, 09:15 AM
I'll take the full kit
914-300Hemi
Sep 21 2018, 09:35 AM
Mark,
I will take a kit.
mobymutt
Sep 21 2018, 10:51 AM
I'd take a set of pins.
913B
Sep 21 2018, 11:29 AM
I would like a set.
Thank you
Mikey914
Sep 24 2018, 12:02 AM
PMs sent to all so far
Krieger
Sep 24 2018, 07:37 AM
I'd like a pair of the oversize pins.
mlmgm
Sep 24 2018, 08:42 AM
Two sets of pins please
maf914
Sep 24 2018, 09:16 AM
One kit please. Thanks, Mark.
Beakster
Sep 24 2018, 09:43 AM
I will get a kit ..Please .... Thanks Mark
rmdinmd
Sep 24 2018, 11:59 AM
set of pins please.
Niklas
Sep 24 2018, 01:13 PM
5 sets please.
Firstcar
Sep 24 2018, 01:16 PM
Mark,
I’d like one set of pins please.
Thx.
-Scott
914four
Sep 24 2018, 08:04 PM
TGM
Sep 25 2018, 11:10 AM
I would like a kit.
Mikey914
Sep 25 2018, 04:02 PM
PMs sent to all to this point,
914four
Sep 29 2018, 08:01 AM
Received my door pins and it fixed the door popping problem I have had for many years. I thought the only way I would be able to fix it was to have the holes welded up and re-drilled to the correct dimension.
The slightly larger pin fixed my problem and now my door opens and closes smoothly just like new.
Thank you 914Rubber!
Kelvin
914werke
Sep 29 2018, 12:19 PM
QUOTE(914four @ Sep 29 2018, 07:01 AM)
Kelvin
Curious about this, since the issue is that over time the the door rollers don't roll anymore and instead glide across the nylon wearing it out.
At same time the additional stress pulls the pin/jamb bracket over & over till one or both wear.
The Jamb bracket tends to oval so the sound is often the pin moving back/forth in the bracket.
How does the oversize pin fit without enlarging or correcting the shape of the brkt hole?
Mikey914
Sep 29 2018, 10:23 PM
The mode of failure is actually galvanic corrosion. It takes metal off the pin and aluminum. My pins still fit the bracket.
914werke
Sep 29 2018, 11:45 PM
So your refering to the Arm (alum) & pin (steel) wearing?
While I agree that occurs, my question is re the Jamb bracket.
rob gannon
Sep 30 2018, 07:30 AM
Received and installed pins yesterday. It took care of the popping problem!
Yeah! It’s been driving me crazy for years.
Thanks,
Rob
North Coast Jim
Sep 30 2018, 09:48 AM
QUOTE(Mikey914 @ Sep 20 2018, 01:42 AM)
Since I started this thread and am still looking for a solution I'll take two pins. I already have your kit to rebuild the stays. Hope this works. Do I need to go your site to order ??
mb911
Sep 30 2018, 10:58 AM
Very nice quality parts. For $44 you cant come close to beating.. Great job Mark
Mikey914
Sep 30 2018, 10:11 PM
Pms sent to all so far
And Thanks
Larmo63
Oct 1 2018, 11:01 PM
I'll take a set of pins, please.
Although, I think that click-click noise is pretty sexy.
