QUOTE(tazz9924 @ Oct 10 2018, 09:01 AM)
QUOTE(widebody914 @ Oct 8 2018, 09:56 AM)
Ok sorry I should have been more descriptive of my build I have a 914 group5 wide body with a Chevy v8 and I also have a 5x114.3 bolt pattern and my wheels are BBS LMs 18x11 front 18x14 rear. As soon as I figure out how to post pictures I will. If anyone has Instagram my name is @anigav_480
Thanks for all the replies
Car in question:
That bolt pattern could be a blessing or a curse being a common Ford pattern.
On the plus side tons of big brake kits for Mustangs so the aluminum hats are available however the rotor offset might be funky. You will also have to deal with the hubs being so large in diameter, I ran into this when I did a 4x100 conversion on 914 years ago.
I would research what people have done with earlier 911s and contact Wilwood or Patrick motosports.
Might have to piece something together, but see below for some ideas.
https://www.rsrproducts.com/911-brake-systemsYeah true true and willwood is good help but I live by Patrick Motorsports and unless you have a ton of money they will not help
