QUOTE(GregAmy @ Apr 20 2019, 07:34 PM)
Is that cage above being built to a specific sanctioning body's regs? May want to review those regs. It would not be acceptable for SCCA Club Racing:
"Braces must be attached as near as possible to the top of the main hoop (not more
than 6 inches below the top), and at an included angle of at least 30 degrees."
?From your quote:
9 C. Roll Cage Bracing
1. The main hoop must have 2 forward braces extending from the hoop and attached to the frame, monocoque, or front hoop. Braces must be attached as near as possible to the top of the hoop but must not be more than 6 inches below the top and at an included angle of at least 30 degrees.
or 9.4.B1c
c. Cars must have 2 braces extending to the rear from the main hoop and attaching to the frame or chassis. Braces must be attached as near as possible to the top of the main hoop (not more than 6 inches below the top), and at an included angle of at least 30 degrees.
In a 914, Is a short rear brace to the inner frame at the top of hoop inside the cabin acceptable?
such as in:
9.4.c.2.e. On cars where the rear window/bulkhead prohibits the installation of rear braces (e.g. Honda del Sol), the main hoop shall be attached to the body by plates welded to the cage and bolted to the stock shoulder harness mounting points. This installation design must incorporate a diagonal bar connecting the top of the main hoop to the lower front passenger side mounting point (Petty Bar).
Hi, still building the cage, not building for SCCA club racing, rather tarmac rally. Will be adding braces high on the main hoop to above the seatbelt anchor bolt frame. Main hoop diagonal, harness cross brace and roof diagonal. The cage is FIA spec kit, but I've modified it so the upper main hoop stays don't travel through the rear window.
options to modify further, always good to build it for as many venues as possible, (ie the next owner)
Any suggestions appreciated, and thanks for the nudge to check roll cage rules again.
Cheers
