andys
Sep 12 2005, 12:34 PM
Don't ask me why I chose blue. It photographs better than black.
Close of bottom left.
Andys
andys
Sep 12 2005, 12:37 PM
Wilwood mechanical spot caliper. I designed the parking brake cable bulkhead and the hydraulic brake line bulkhead to pick up the stock locations, thus the stock connections.
Close of parking brake:
Andys
TravisNeff
Sep 12 2005, 12:39 PM
That is trick!
tat2dphreak
Sep 12 2005, 12:41 PM
those look amazing!
andys
BTW, the heavy P-brake return spring is a must, otherwise the cable will not properly extend and the P-brake pads will drag.
Andys
Aaron Cox
Sep 12 2005, 01:29 PM
dude!!!
Andyrew
Sep 12 2005, 02:03 PM
when are they going in production!!!
Cool beans!!!!!
914MF
Sep 12 2005, 02:35 PM
Britain Smith
Sep 12 2005, 03:52 PM
Those look awesome.
However, what is the advantage of your design? Maybe I missed something, but you still don't have a method to adjust rear camber with this set-up. Just wondering.
-Britain
Aaron Cox
Sep 12 2005, 04:08 PM
QUOTE (Britain Smith @ Sep 12 2005, 02:52 PM) |
Those look awesome.
-Britain |
bigger bearings was one thing noted, along with late model hubs to facilitate beefier axle install.
He also stated that he could "BUILD" up to 3 degrees of camber in to them, but to adjust, you still require shims like stock
andys
Sep 12 2005, 04:44 PM
QUOTE (Aaron Cox @ Sep 12 2005, 02:08 PM) |
QUOTE (Britain Smith @ Sep 12 2005, 02:52 PM) | Those look awesome.
-Britain |
He also stated that he could "BUILD" up to 3 degrees of camber in to them, but to adjust, you still require shims like stock |
Yeah Aaron, you're right.
I also placed the (larger late 911) bearing 1.20" further outboard to keep the wheels spacers down to a reasonable thickness for my 993 wheels, and to facilitate CV adapters for my transaxle.
The design was to simply replicate the existing trailing arm (with some necessary changes) for a V8 street application. I would have approached the design differently for a track car.
Andys
Mueller
Sep 20 2005, 11:32 AM
QUOTE (andys @ Sep 12 2005, 11:37 AM) |
Andys
neat !!!!!
I was just on evilBay looking at those Wilwood calipers....hmmmmm....mind if I "borrow" some ideas from your design??
(not for commercial use )
wbergtho
Oct 31 2005, 01:38 AM
I had Randy Beck in Upland, Ca fabricate my rear trailing arms utilizing 930 turbo calipers & rotors...also with the 930 parking brake integrated within the rear rotors as on a stock 930. I'm sure anyone will decent fabrication skills could copy my set-up.
Bill
74 914
White Sheridan bodied w/ LS6 (500HP)
redshift
Oct 31 2005, 01:48 AM
Ok Andy, you got the job. Starts tomorrow, $9/hr, and full benefits. *(ham sandwiches, 2x per day)
Great work.
M
Verruckt
Oct 31 2005, 05:42 AM
Andys
Eagerly awaiting the day when you start a new thread in the vendors section.
Brando
Oct 31 2005, 01:11 PM
Hot damn Andy, that's some marvelous work.
andys
Oct 31 2005, 02:44 PM
QUOTE (redshift @ Oct 30 2005, 11:48 PM) |
Great work.
M |
M,
If I paid you the $9/hr, it probably would have cost me less.............But those ham sandwiches would do fine, as long as there was something to wash 'em down with.
Andys
Aaron Cox
Oct 31 2005, 02:48 PM
QUOTE (andys @ Oct 31 2005, 01:44 PM) |
QUOTE (redshift @ Oct 30 2005, 11:48 PM) | Ok Andy, you got the job. Starts tomorrow, $9/hr, and full benefits. *(ham sandwiches, 2x per day)
Great work.
M |
M,
Andys |
tap water
lol
