DRPHIL914
Feb 27 2019, 08:19 AM
QUOTE(mb911 @ Feb 26 2019, 06:31 PM)
Just bought a maxjax for 1500 today delivered.. Was a flash sale.. Looking forward to using this..
direct or Costco?
mb911
Feb 27 2019, 11:18 AM
QUOTE(DRPHIL914 @ Feb 27 2019, 06:19 AM)
direct or Costco?
Direct..
ctc911ctc
Apr 3 2019, 08:10 AM
On my list - went to buy it today - price raised to 1279......sigh
QUOTE(mb911 @ Feb 17 2019, 09:28 AM)
QUOTE(cuddy_k @ Feb 15 2019, 04:25 AM)
Quick Jack is another great option. The lift sections are trapezoidal so they don’t need to be anchored to the floor and there’s no minimum concrete thickness. It doesn’t lift as high as max Jax, but the 21 inches or so is more than adequate to work on a creeper. In my opinion, there are really only two workable heights anyway....on your back or above your head. If you don’t have the ceiling height for the latter, quick jack is an easy and portable solution. I use it in my small garage and there’s an unboxing, setup, and 914 lift video in my signature...
Click to view attachmentThose are on sale this weekend at home depot for 1100. Tempting
Carl La Fong
Apr 3 2019, 10:15 AM
Mid size lifts are great. This garage has a 7 foot ceiling. The lift will go up almost the full 4 feet if the targa bar and the windshield rise up between the ceiling joists. A cheap furniture dolly (shanghai tool supply) and beech chair are great for working under the car. This lift also came with rubber pads that slide on the lift arms allowing for more stability.
rhodyguy
Apr 3 2019, 11:22 AM
Welcome back Elliot! You've been missed 'my little chickadee'.
76-914
Apr 3 2019, 12:52 PM
QUOTE(rhodyguy @ Apr 3 2019, 10:22 AM)
What gave it away, Kev? The 747 decal; his mastery of spelling; the OSHA rejected chair; or perhaps the pseudonym? Psuedonym? Wait a
minute. Elyut would never use a pseudonym. In fact, his pontifications against such were posted quite often.
rhodyguy
Apr 3 2019, 01:01 PM
Man...that's a lot of quotes. Quote happy Wednesday!
That was the first kernel to fall from the silo. Wiki took me to 99%. Pictures?
100%.
Carl La Fong is a Psuedonym WC Fields used for a screenplay he wrote. Watch much TCM?
Mystery over. So...do we address you as Carl or Elliot?
Carl La Fong
Apr 3 2019, 02:46 PM
QUOTE(rhodyguy @ Apr 3 2019, 12:22 PM)
Do I know him?
Carl La Fong
Apr 3 2019, 02:48 PM
I have no idea who you are all talking about.
Mark Henry
Apr 3 2019, 02:54 PM
QUOTE(Carl La Fong @ Apr 3 2019, 04:46 PM)
Do I know him?
I thought Elliot's new user name was "Wei Tu Low"
sb914
Apr 3 2019, 04:29 PM
QUOTE(Carl La Fong @ Apr 3 2019, 01:48 PM)
I do!
914-300Hemi
Apr 3 2019, 09:41 PM
I just placed an order for a MaxJax 2 post lift. Looked at scissor lifts but didn’t like the weight, extra delivery fees and i had to build ramps.
It gets delivered next week.
Krieger
Apr 3 2019, 10:41 PM
I'd recognize that scoop anywhere!
mb911
Apr 4 2019, 05:46 AM
QUOTE(914-300Hemi @ Apr 3 2019, 07:41 PM)
After having mine for a few weeks I can tell you this. The hoses are really in the way. I need to find a way to cover them like what they do for trade shows and electrical cords..
76-914
Apr 4 2019, 08:34 AM
I'm lucky there. My hose slips into the recess of the slabs expansion joint so the hose is semi recessed. The best accessory I have found for my Max Jack are the Harbor Freight small furniture dollies. They allow me to use the 4" extensions that come with it. Raise the car 3-4" then lower onto the dollies. Once on the dolly the extensions can be fitted. Why furniture dollies instead of blocks. Try it and you'll find out. Bottom line: Any lift is better than no lift. Get what you can afford and whatever fits.
mlindner
Apr 4 2019, 12:15 PM
Ben, just get a cement blade for your circular saw. Saw two groves 3/4 inch apart and 3/4 inch deep, hit with hammer/chisel. I ran mine then filled channel with flexible cement caulk. See bottom right corner gives you a little peak of the flat floor. Best, Mark
914_teener
Apr 4 2019, 12:24 PM
QUOTE(mlindner @ Apr 4 2019, 11:15 AM)
Click to view attachmentCurious......
What is the capacity of that lift?
Apr 4 2019, 12:26 PM
Hose Protector Ramp - sold on Amazon
mlindner
Ben, found a better shot before I filled the grove. Again, lower right corner.
mlindner
Apr 4 2019, 12:29 PM
914 teener. Bendpak, 6,000 lbs. love it.
mlindner
Apr 4 2019, 01:11 PM
ctc911ctc, just looking at your garage size again....a two post lift as nice as they are will take up much of your space with the car in. A scissor lift would give you that space back but limited as to the height. For 911s and 914s the scissor is especially nice since there is nothing in the middle of the car (exhaust, drive line etc.) Have fun, Mark
mlindner
Apr 4 2019, 01:29 PM
Just noticed, two out of the three two post lifts mentioned are to wide for your garage....over 120 inch.
mb911
Apr 4 2019, 03:08 PM
@mlinder
I suppose I could do that.. Not a bad idea..
914_teener
Apr 4 2019, 03:26 PM
QUOTE(mlindner @ Apr 4 2019, 12:11 PM)
Do you think with a 987.1 I could still get at the water pump in the front of the engine?
Thanks for those pics.
Dredwin
Apr 4 2019, 03:50 PM
I embraced my hose...bought a pool noodle, cut it open and ran the hose through it. I was worried I'd step on the hose and puncture it so at least the pool noodle protects it. I have the scissor lift though and wanted the flexibility of moving the lift around (and wanting to cut the floor up).
mlindner
Apr 5 2019, 05:12 AM
914 teener, good question and I do have a Cayman.....I have not done the water pump or belts yet. I believe with the extra work of putting the extension on and getting the car another 8 inch above the lift it would work. The few pictures I have of the Cayman were just to clean last year before the parade. Best, Mark
Click to view attachment Click to view attachment
Mark Henry
Apr 5 2019, 06:10 AM
QUOTE(914_teener @ Apr 4 2019, 05:26 PM)
I'd go for 2 post like maxjack on the water cooleds, crapload of stuff runs down the center. I the took the tranny and driveshaft out of a C4S yesterday morning, IMS solution, no way could you do that with a table lift.
Today I have to replace the clutch slave cyl in another C4S, PITA getting my big mitts up there even with a 2 post.
mlindner
Apr 5 2019, 07:01 AM
I agree Mark, with doing that much work...trans, engines a two post is a must.
Hans Zupp
Apr 25 2019, 09:34 AM
QUOTE(sb914 @ Apr 3 2019, 11:29 PM)
I do!
I zink I no whoo he be ...
Krieger
Sep 28 2019, 10:43 AM
Now I am considering the move to the two post lift. I have had an EZ car lift for at least 10 years, but I want to stop rolling around on the ground and stand or as close to that as possible. I have a good size garage that is 25'×25' with 10' high ceilings. What are the electrical requirements for these lifts? Is 110 enough?
914-d
Sep 28 2019, 10:58 AM
One of the lifts I have is 110v, the other is 220v. The first is sold by
twinbusch.com. It is rated 9500 lbs, but6 nowhere near as stout as my forward lift rated at 9000. Both work fine
ClayPerrine
Sep 28 2019, 08:19 PM
QUOTE(Krieger @ Sep 28 2019, 11:43 AM)
Every two post lift I have ever seen requires 220V ac to work. Have an electrician wire up a new circuit from your breaker panel to the lift.
mb911
Sep 28 2019, 08:32 PM
The maxjax works on 110 .. I have used all kinds and this is my favorite so far..
oldschool
Sep 29 2019, 01:07 AM
Click to view attachment I got this off of crags list its a tire chief has work out fine.
sithot
Sep 29 2019, 05:39 AM
A friend has put these in his latest dealership. If only....
https://rotarylift.com/wp-content/uploads/2...y_Smartlift.pdfClick to view attachment I like no encumbrances under a car. Having complete access to everything was the reason I went with a 2 post.
The 4 post storage lift allows some work but it's still best used as a storage device. Bumping your head is a common occurrence.
FWIW: It's apparently a
little known fact that a third "leg" is recommended for 2 post lifts.
I use an older Rotary screw jack for extra stability when they're up high or if there's going to be some "tugging" on non-compliant nuts and bolts.
The Rotary RS4 is sold on Amazon for about $140. Well worth it for added insurance.
Also recommend HD rubber lift pads that are cut for seam welds. Easier on the chassis.
ClayPerrine
Sep 29 2019, 12:21 PM
QUOTE(sithot @ Sep 29 2019, 06:39 AM)
FWIW: It's apparently a little known fact that a third "leg" is recommended for 2 post lifts.
I always put a stand under the back of a 914 when I have it up on my lift. I have seen a car fall off a lift, and I don't want it to happen to me.
I am not paranoid... just convinced the world is out to get me.
mb911
Sep 29 2019, 12:52 PM
I need one that is about 48" might have to make one.. I do like the idea..
sithot
Sep 29 2019, 03:23 PM
QUOTE(mb911 @ Sep 29 2019, 02:52 PM)
You could start with this. It's 80"
Stark Screw Jack
