SH -
Only makes sense, I agree - especially since I did not know about the cam load.
I do know this: Original Owner's Manual shows car was delivered on 1/27/76, and has dealer service stamped showing 13,971 miles on 1/25/1977 in Buena Park, CA.
I also have Porsche dealer invoice showing 56,496 on 8/31/2001. Another showing 58,537 on 11/29/2002.
That's 44,500 miles in 25+ years, or only 1,700 miles/year. Extremely low UNLESS the car sat for a number of years. Which is also not unusual for these cars.
Car indicated 60,600 on 9/22/17 when I purchased it and had been sitting in one place in my friends barn for 12 years. It sat in my garage for almost 2 years. 14 total recent years, zero miles. So between '01 and '06 it was driven 4k miles in the last full year it was driven.
Wear on the car is commensurate with a 60k car. Interior is very nice, so are pedals.
But as you say, who knows? Best to check all when engine is out.
If cam is worn, I'm going with a cam for the Weber 44's.
GN
QUOTE(Superhawk996 @ Aug 25 2019, 01:32 PM)
QUOTE(Gatornapper @ Aug 25 2019, 01:54 PM)
SH -
Totally get it. But, mine does only have 60k miles on it.....pretty sure that's fairly accurate.
Debating opening the case if I do the C's & P's.......kinda know I should, but also know it will likely lead to spending money that might not be necessary - like a cam for the carbs.....
Call me a doubting Thomas but I think very few of these cars have accurate mileage unless they can be backed up with records from new.
Trans cables are easily disconnected. Speedo/ODO is an easy swap. Think about it. Cars 40 years old with an average of only 1.5K miles per year? Not likely. I know some are low mileage originals out there, but, most aren't. Mine had ODO at 60K but shows every sign of that not being correct.
With respect to opening the case, any consequences of "while I'm in there" syndrome of swapping to 102mm pistons, stroker cranks, etc. are on you.
Granted a fresh set of bearings (crank, rods, and cam) and a Gasket kit will set you back $250, but, if everything else checks out there is no harm done in putting it back together with nothing more than fresh gaskets if it really is OK and low mileage.
I'm currently rebuilding GA000099 and it indeed a low mileage engine with no real wear on the pistons, or cylinders, but the ring end gaps are out of spec and showing some wear.
Even at 60K you're likely to find that you need a cam. The design of these cams is such that a single lobe is shared with two cylinders. That essentially leads to a doubling of wear at the center of the lobe. Found the stock cam in GA000099 and as stated, the lobes are showing wear even though the P&C do not.
I'd just suggest that you evaluate as you go and adapt accordingly.
