Sorry, I thought I had a picture of the clean pump, but the car previously had a heavy duty aftermarket pump, I don’t recall the name, it’s at the engine builders now, but it’s huge. Here it is, really dirty, during disassembly, internals are perfect. I have 2 filters, on on the stock 6 tank and the other on engine as seen.
I never had any oiling issues on track with this, 911 style thermostat, and rx7 cooler in front, using a real 6 tank.
Also used modified tuna can on bottom. Only concern I ever had was the hose being at the low point of car (4” per POC rules) although never had any issues... Click to view attachment
yeahmag
Feb 3 2021, 04:56 PM
Looks like a BugPack pump. Did you happen to record CHT on the cylinder you had a seat drop? Just curious if there were any warnings.
ChrisFoley
Feb 3 2021, 06:23 PM
Autocraft Dry Sump Pump.
infraredcalvin
Feb 3 2021, 07:18 PM
QUOTE(yeahmag @ Feb 3 2021, 02:56 PM)
No the pump had some other name inscribed, like SC performance, I just can’t remember. As for CHT no, the build was over 20 years old with unknown mileage. I could tell it was tired, I had planned on top end rebuild and ring check at the end of the season (1 more race). I was at chuckwalla when it broke, I had noticed a 4 sec add to my times from morn to afternoon sessions the previous day, at first I thought it was me. Then on Sun I could tell it was down on power, but I was determined to keep up/pass a spec boxster and I was pushing really hard - no overrevs, just hard on brakes and cornering. I had caught up to where the following lap I was going to challenge for position, then it let go... oil temps were at 190-200 as I just eyeballed in the straightaway right before the blow, nothing looked out of wack... I think it was just time.
infraredcalvin
Feb 3 2021, 07:26 PM
BTW, the valve head broke off, no dropped seat. Probably from an over rev that kissed the piston when I missed 5th and locked the wheels in 3rd on turn 8 at Big Willow at my first race of the season....
Tdskip
Feb 4 2021, 08:27 AM
Thanks for the updates - sounds like you have a good build plan underway.
infraredcalvin
Feb 4 2021, 10:32 AM
QUOTE(Tdskip @ Feb 4 2021, 06:27 AM)
Plans changing really fast, counting on things looking different Saturday
Tdskip
Feb 4 2021, 10:36 AM
QUOTE(infraredcalvin @ Feb 4 2021, 11:32 AM)
One musty flexible like a lotus leaf grasshopper Antique horsepower where you find it
infraredcalvin
Feb 6 2021, 08:38 PM
The 914 gods were on my side and I finally picked up my dream car! Many of you saw the euro 6 for sale for a short time, I’m the lucky bastard who brought it home! She’s right out of trailer from bringing her home, some spit and shine she’ll look almost too good to get out on the track. Thank you to prior owners PL (RIP) and his wife JL for taking a chance on me. More details after I get settled...
BTW, anyone interested in a 71 914-4 race car with a freshly built FAT upright 911 fan motor (build currently in progress)? She’s light and fast... keep an eye on the classifieds as she’ll be up soon!
sixnotfour
Feb 7 2021, 01:10 PM
Nice Upgrade !!!
Charles Freeborn
Feb 17 2021, 11:18 AM
Sweet!
If you'd be interested in selling the T4 engine separate from the car let me know.
infraredcalvin
Feb 18 2021, 12:29 AM
QUOTE(Charles Freeborn @ Feb 17 2021, 09:18 AM)
Sweet!
PM sent
ndfrigi
Feb 18 2021, 12:58 AM
Congrats on your new beast @infraredcalvin Maybe you can show your new car on the coming SoCal meet in San Dimas.
infraredcalvin
Feb 18 2021, 08:13 AM
Thanks, I’d like to, but I’m still trying to get her sorted. Finding out there is no easy way to change the lower spark plugs without dropping the engine. It’s coming out anyway, valve job and closeup inspection as she’s been sitting awhile. Once done you’ll see her on the street as well as the track.
infraredcalvin
Mar 17 2021, 03:08 PM
Who would have thought spark plugs would be on back order... yanked the motor, did the valves, spot on, took a look inside, I think I still see assembly lube... how many miles are on this engine???
Ordered valve cover seals, will button her back up.
Tdskip
Mar 19 2021, 10:51 AM
Score!
Justinp71
Mar 22 2021, 09:56 AM
Nice Motor! What are the specs on it (size, cams, etc...)?
infraredcalvin
Mar 23 2021, 08:12 AM
Motor came with limited info, but finding notes referencing: 3.4 max moritz 9.8 comp pistons with 964 cam 46 ida Webers Electromotive HPV-1 dual plug ignition
Once I get it dialed in at the track I’ll get it up for some dyno pulls
Tdskip
Mar 23 2021, 09:47 AM
I have 964 cams in the ‘74 911 with the 3.2, they work well.
campbellcj
Mar 27 2021, 08:07 AM
Wow congrats, that looks like a lot of fun!
slivel
Mar 27 2021, 11:45 AM
QUOTE(infraredcalvin @ Mar 23 2021, 07:12 AM)
Similar build as my engine except I have GE 80 cams. For comparison, mine made 290 at the wheels.
infraredcalvin
Apr 10 2021, 10:15 PM
Got motor back in, everything hooked up, 6 qts of VR1 for starters, immediately fired, but took about 10 tries to prime the carbs before she stayed running.
Was sitting in the car keeping the rpms up when I started hearing loud popping and what I assumed were engine bits being thrown to the floor...
A crew is retrofitting the lights in the warehouse, these were stacked on the W/D near the rear of the car, the exhaust vibrated them off.
Charles Freeborn
Apr 11 2021, 07:02 PM
QUOTE(infraredcalvin @ Apr 10 2021, 09:15 PM)
I was able to tune most of the popping and hacking out, but on three of the 6, idle mixture had no effect, time to start taking apart and cleaning out...
infraredcalvin
May 1 2021, 10:15 PM
Still have the 4, finally got my new FAT build back. According to the builder, this is what 180 horses looks like...
Start with just cleaning the idle jets if you haven't already... Then if needed pull out the idle mixture screws (with idle jets out) and blow out with carb cleaner.
infraredcalvin
May 2 2021, 11:56 PM
Thanks, I ended up, rebuilding the carbs, glad I did as some of the gaskets were ready to start leaking. It also gave me some piece of mind that gaskets were not the culprit for my current tuning issues.
I was still getting spits and misses, worse than before, so I attached my lm2 data logger and pulled spark plugs. She was running pig rich across the board. PO had notes about finally getting the carbs dialed in, so I was trusting his base settings, my gut kept telling me everything was too big...
I finally got the balls to change main jets to 160 and idles to 50, wow what a difference! No more popping and missing, still rich, but no flat spots where the motor was getting bogged by fuel, moving closer to the sweet spot.
I started having issues with my lm2, so I installed a permanent afr gauge in the cockpit. No data logging, but I can start fine tuning now... anyone know any good carb tuners?
Looks like I’m going to make it to big Willow the weekend of the 15th... looking for a trailer to rent also...
My girls wanted to see some purple on the car so I’m playing with livery schemes on photoshop.
Fyi, they run rich all the time. This is so the transition from idle to main circuit is smooth. These were designed for max power and with economy not in mind. You sound like you have it tuned fairly well.
IMHO main thing is to have it in the 12's or low 13's AFR at full throttle in the high RPM band, then you won't do any damage to the motor.
I'm only running 160 mains on my 3.2 to give it 12.8 -13.4 AFR (@68f outside air temp) at the high end which is good. This motor has cams and headers, should be about 280hp. I would think you might need larger jets? It also depends on on your air jet sizes too, mine are 190. I have F11 emulsions, I thought about trying F7's but it is running good right now just wish it was a little leaner at idle and cruise (12 afr best case).
Justinp71
May 4 2021, 04:26 PM
Also I'd just drive it to the raceway... much more fun! Get AAA 200 mile incase of a mechanical breakdown. Only thing to consider if you do break on the raceway AAA may not tow you out of the raceway not sure. I've done about a half dozen track days this way. Would probably be nice to eventually get your own small 914 size trailer if you go alot.
infraredcalvin
May 4 2021, 11:58 PM
I’m hearing you about running rich. I’m still getting into the 10s at WOT, track is 1500 ft higher in elevation than my house, so rich here is going to be really rich there. I may try downsizing mains and idles one more time, see where that gets me. These afr gauges are a godsend and a curse, in the search for perfect AFRs.
As for driving there, well not yet, a uhaul will work fine, it’s easier to drop the car at the track and not worry about it in a hotel parking lot.
Justinp71
May 6 2021, 04:13 PM
Wow, 10:1 at WOT that is rich, got some power on the table there...
You may want to consider a more open yet still combining exhaust. Knight racing talked me into a single magnaflow 2x2 muffler. If you're looking for more power, that should help lean it out too.
No videos or real pics, but Willow Spring's was a bit humbling for me last weekend. Car needs A LOT of dialing in.
Motor ran fine, but I feel I'm missing 50-75 horses somewhere in the tune. Chatted with a few shops that were there, looks like it'll be headed to AASE shortly for a test and tune.
I was really uncomfortable in the car, seat too high, wheel too close, shifting with the Vellios 915 is vague a best. Enough with the excuses, but I was 8 seconds quicker per lap in the old car... huh go figure...
At least I now have a baseline and can start tweaking to make it mine!
Nice! I'm sure you'll be knocking the seconds down with getting it tuned in!
How do you feel with your suspension? Able to carry a lot of speed thru the turns?
Might be able to keep it in the taller gear thru a turn to gain time if shifting is real slow, that big 6 will just push thru. I've done this in other cars and been faster.
Are you still 10:1 AFR at WOT? That will hurt power. Also if you don't already have it consider combining your exhaust outlets. Timing would be another good area to check.
I am thinking of going with a kirkey seat next to gain headroom, probably direct mount.
infraredcalvin
May 22 2021, 11:04 AM
Right now engine tune is my highest priority, yes as I glanced down I could see the AFRs creeping into single digits, so it’s stabilizing in the low 10s. The motor seems really slow to rev, like it’s running out of breath... possibly a timing issue. I found some old dyno sheets in some of the piles of stuff that came with the car, it was showing high 160s to the wheels. Im not sure if it’s the dyno for this motor as it seems really low for what I’m told is in this car, I think it should be well over 225 if not 250 at the wheels. But right now my butt is saying it might be true, could it eally be off close to 100 hp??? sounds like wishful thinking... we’ll see.
Regardless, torque is nice enough to hold tail to the ground, it spins slow, running out of steam around 5k - maybe cam choice? Lots of variables, that’s why I’ve got an appt set up with experts, want to be sure I’m maxing out what I have before changing expensive motor parts out.
As for handling, cars seems neutral, seems like I could hold much more though the corners with new tires, the old r888 are really unpredictable on this car, due to sizes I’m looking at yoko a052, hear they are the best for 200 tw at the moment...re71s don’t come big enough for 16 in rims. And my pocket can’t afford Hoosiers yet...
As for seat, yes, need to get it on the floor. I’m not a fan of any aluminum seats, watched a fellow racer get trapped cause the al seat clamshelled around his body, and he couldn’t get out without help prying the seat open. thankfully no fire, but it was a scary moment for sure. Lots of people run them, and this was prob a fluke, but made the decision to stay away since then.
I got my Recaros on the floor in the old car by taking out the cross support, it gave me almost 2 more inches clearance. I don’t want to do that in my 6, so I’ll have to come up with something else, but an inch would be a huge help.
Gotta pin down front of hood. PO put spacers at the rear of hood, prob to let all this air out from the nose...sheesh it’s like a parachute! I now know why the factory has 4 pins on the nose (mine only has 2 just behind the light buckets).
wndsrfr
May 22 2021, 02:20 PM
QUOTE(infraredcalvin @ May 22 2021, 09:04 AM)
On tires, check again on the Bridgestone RE71R's....I'm on 225 on 16's & really like them, very sticky....
infraredcalvin
May 22 2021, 07:49 PM
I had the RE71s on my old car (205/50/15) loved them, the new car has 245/45/16s in the rear... so trying the yokos...
stownsen914
May 23 2021, 08:11 AM
QUOTE(infraredcalvin @ May 22 2021, 01:20 PM)
Wow. You may want to consider looking into different methods of exhausting air from the front trunk area. It's tempting to use the rear of the front trunk, but it's not ideal as it's a high pressure area (being immediately in front of the windshield). In fact, air may be flowing IN there instead of out. This might explain the hood popping up like in the pic - the air is working overtime to get out.
stownsen914
May 23 2021, 08:30 AM
On the engine tune, AFRs around 10 is way rich. For sure you need to go leaner. Idle jets barely matter on track, drop the mains another couple sizes and see where that gets you.
Someone mentioned air correctors. You don't mention what size those are, but they're important too. Air correctors affect top end more than mid range. If the rich running starts like 5000 RPM and up, consider swapping air correctors (keeping in mind that the effect is opposite that of the other jets, so go larger to go leaner). If you're rich throughout the RPM range, stick to adjusting the main jets first.
Missing that much hp makes me wonder if something is fundamentally wrong. Timing is a good place to look. Make sure total advance is in the range you want, like low 30s for single plug or mid/upper 20s for twin plug. Or a major restriction on intake or exhaust. I assume you have the usual PMO style carb filters? On the exhaust, it would have to be a cork to kill 50 hp though. What do you have?
infraredcalvin
May 23 2021, 10:12 AM
QUOTE(stownsen914 @ May 23 2021, 07:11 AM)
Hmmm never thought of it that way, I would like to adjust anyway, the stewards kept asking to check it as it looks like it’s not fastened down just sitting there. Also could be shock mounts preventing it closing all the way too... gotta investigate further.
The current air exhaust hole is tiny, and the cooler has no shroud, I’m losing a ton of efficiency here... sorry for the flipped picture, but here is my front trunk.
It's a little hard to figure out the orientation from the picture. A couple comments though. On a track car, a fan shouldn't be necessary. In fact, it'll probably just get in the way of the air flow, which should be enough pretty much any time the car is moving. Fans are more for stop and go traffic situations. As you suggest, air exhaust is just as important as the air coming in. If it can't get out, nor more air will come in, and the cooler won't do its job. Shrouding on the inlet side is very important. Air doesn't like to go through a cooler, it'll choose pretty much any other path you give it. So the inlet shroud needs to go from the inlet and guide the air to the face of the cooler with no gaps, etc. on the seems. 1/4" is too much. You can use weatherstripping foam like you get at Home Depot for windows and ducting, or even tape to seal seams and cracks. Shrouding on the outlet side of the cooler isn't as important. It's still a good idea, but not critical. But the air needs an opening in a low pressure area to escape the trunk. Wheel wells or trunk floor are good places. Some people just pull out those round factory plugs in the floor. Hood is good too if done right, but then you're cutting bodywork - not everyone's preference.
I feel like the PO did his reading, bought a bunch of nice parts and put them all on the car. The whole thing seems to need initial tuning- fine tuning....
As for the car being a “track” car, technically it’s still street legal, so it’s a track oriented street car, which for now is how I’d like to keep it.
Justinp71
May 24 2021, 03:30 PM
I agree may have something fundamentally wrong. Check your spark plug wires and fire order. I had an old chevy v8 along time ago that had two close wires swapped with similar issues to what you are describing. Would make sense why your afr is so low, actual unburnt fuel in the exhaust. My 3.2 with DC40 cams takes off like a banshee and yours should be faster, for comparison I am about 12.5:1 AFR at WOT on the high end.
infraredcalvin
May 27 2021, 11:16 AM
@stownsen914 I never answered your question about the carb specs. Sadly I'm a noob as it relates to carbs, which is why I'm so thrown by this. When I did the carb rebuild I was able to figure out the following, but as i go down with the main jet and idle jets, my gut is telling me that everything else is too big...
Weber 46 IDA 3C
Idle jet: 50 Main jet: 140 Emulsion Tubes: F7 Air Correction: 170 Choke: 42
Air filters are K&Ns with a flat rain shield type top. Exhaust are equal length 6 headers at 1.625 and a monte 2 in 2 out muffler.
wndsrfr
May 27 2021, 07:17 PM
QUOTE(infraredcalvin @ May 27 2021, 09:16 AM)
I'll chime in about the air filters with rain hats....I found that mine only had slightly more than 3/4 inch from the top of the velocity stack to the metal lid. That caused what I think was significant shrouding of the air flow. My solution was to go to the ITG type filters that have only foam above the edge of the stacks so no shrouding will occur...ymmv...
infraredcalvin
May 27 2021, 09:04 PM
QUOTE(wndsrfr @ May 27 2021, 06:17 PM)
Hmmm that did cross my mind, but I see this setup consistently, so I dismissed it...could be why she seems out of breath on the top end...
