I have been working on the car - down to lots of little tidie up things.
Getting engine cover on - cut off the cross support
Mounted rear trunk lid and installed some gas struts to keep it open
Pulled Accel coil out of it's big cover and put it back with a stock GM cover
Installed some new door seals
B piller rear door glass seals
trunk seals
reinstalled the rear window - it was loose
While refitting the rear window I fixed both rear top clamps
Installed some of the carpet kit
Got the hazard and blinkers to work
and more.
Two weeks ago I got the head lights working - link to youtube video:
https://www.youtube.com/watch?v=KX_RLvkssq8&t=35sDrove it around town and down the freeway yesterday to shack it down and see how it fared. So far GREAT!
The Davis Craig electric water pump and controller really do a great job of keeping the engine temps down. Also love the feature that runs the water pump and fan for 3 minutes after the car is shut off. you pull up and park with the engine temp at 185 to 195, depending on your drive, and 3 minutes later the temp is 170 or so.
Not sure how 914 stock suspension is, but this car with it 911 suspension, brakes and 16" wheels is really stable on the freeway. And with the 350 in it it goes from 40ish to 90ish in 3, 4th or 5th pretty quickly.
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachment
