QUOTE(bbrock @ Apr 4 2020, 11:12 PM)
QUOTE(sreyemj @ Apr 4 2020, 07:36 PM)
Did you do anything to the ospho'ed surface before using the epoxy primer (rinsing, sanding, etc)? I can wire wheel it down to bare metal, but there is still going to be a small amount of rust in the pitted metal unless I convert it with ospho before primer. If you wire wheel after ospho you just take off the converted material and potentially expose more unconverted rust.
Yeah. I let the Ospho sit for several hours or overnight. Then rinse with water to neutralize the acid. That will create a white phosphorous coating that will protect the metal somewhat and you can leave it until ready to paint. The go over it with a red Scotch Brite pad to remove the loose powdery stuff. I learned this from a few people on here who restore cars professionally. I've never had any problems with epoxy or any DTM paint sticking to it.
I also do like you are planning and clean as much of he rust out as possible before treating with the Ospho. The Ospho soaks down into the pits rust to convert the rust and doesn't just encapsulate it. It's really good stuff.
I'll try that. The ospho bottle just says dry for 24hr and then paint, but I will definitely rinse first.
QUOTE(bkrantz @ Apr 4 2020, 10:13 PM)
I wonder if all those big round holes were made by the clever PO to do surgery on the original heater hose and then install the cheap replacement.
I'm sure they were, looks like they used a hole saw.
