Full Version: Just cut out on the Fwy
Pages: 1, 2
GregAmy
QUOTE(rjames @ Dec 7 2020, 02:42 PM) *
Have you checked the fuel pressure yet as others have already suggested?
Yup.
And before I bought a fuel pump, I'd ensure thre was 12V going to it. My wager is still on a problem with the electrical connectors/pins to the relay plate. I noted before what I did to resolve the same issue...
http://www.914world.com/bbs2/index.php?s=&...t&p=2538175
914Toy
QUOTE(johnpierre @ Dec 7 2020, 12:28 PM) *
QUOTE(rjames @ Dec 7 2020, 11:42 AM) *
Replacing the fuel pump might fix it, and then it again it might not.
so I just checked with my friend and he said when I was turning the key there was fuel pressure and he could tell fuel was in the rails
so I guess it is not the fuel pump
is there an ECU on this car - the reason I asked is there is a box behind the batter that looks like a electridle unit - could the problem be in there ???
How did your friend know there "was fuel pressure and he could tell there was fuel in the rails"?
sixnotfour
Has your pump been updated or still have the 3 port in the back ?
rjames
Checking for fuel in the fuel rails isn't the same as checking the fuel pressure. To rule out the pump or the fuel pressure regulator you need to know what the fuel pressure actually is.
euro911
JP, You can pick up a fairly inexpensive fuel pressure gauge at AutoZone or Pep Boys.
Also pick up a couple of small hose clamps and insert it permanently inline in the supply line - somewhere you can see it in the engine bay idea.gif
https://www.autozone.com/test-scan-and-spec...ster/273356_0_0
johnpierre
QUOTE(76-914 @ Dec 7 2020, 03:37 PM) *
hey there
thank you for the link but I can't seem to open it
-jp-
euro911
Try this link, JP ... https://members.rennlist.com/pbanders/#Details
Scroll down to the D-Jetronic links
jim_hoyland
And, I had this happen, the fuel pump ground must be secure. A loose or poorly crimped ground will stop that pump.
Common on ‘75s where there’s a chassis spade for the ground.
