QUOTE(Frank S @ Jul 15 2020, 02:27 PM)
Is it the Ignition coil cutting out or do you struggle with sync loss problems due to too high temps at the Crank Pic-Up Sensor?
Do you have a tooth log?
Very confident it's not synch loss; I'm not logging any synch loss at all except when I "burn" with the car running.
Symptoms are stumbles and the AFR momentarily pegs full lean. I replaced the coil with a new one and it briefly got a lot better but it's starting to come back. Usually runs smooth for a half hour, then very light stumbles til about 45 minutes, then very hard stumbles. Died on me yesterday, I had to coast to a stop. Top of the coil was 184F via IR.
I've been told this coil really likes big wires for power and ground, but I'm using AWG14 for both, didn't seem to affect anything.
I'm thinking it's just getting too hot in the location I have it (on top of where the disty was).
We can discuss in your Megasquirt thread, I need some ideas.
Click to view attachmentHi Greg, would be fine with me. But I also think it's a temperature related issue. But after I checked the other post with the underfloor temp meassurements, which is great, I think there is a problem with the engine tune. I'm running much cooler oil and head temps without an additional oil cooler (2056).
But let's discuss this at a different place as it would be misleading here since Rob is running a lager displacement engine which requires additional oil cooling.
