how do you take the motor out of the white fan part?
@DRPHIL914
After having just totally screwed up my blower motor trying to remove the impeller all I can say is DON'T DO IT.
I was willing to risk mine since the fan was vibrating so badly and I could feel significant side play in the shaft. Likewise the impeller already had several cracked vanes before I started this that were deflecting and also causing vibration. I had little to loose.
What a fiasco. It's pretty rare that I get into disassembling something and then realizing that I've just Fuched it up beyond all hope. But this motor assembly is it.
The bottom line is the impeller is held on by a spring clip that clamps the impeller to the shaft. Mine would not release even after removing the clip. Gentle persuasion didn't work. A bit of gentle warming to sofen the platic relative to the steel shat. Nope. Then came the hammer for a gentle tap and then all hell broke loose.
I'm not sure I even want to go into the rest of the story. Needless to say, this one ain't ever gonna be the same again. RIP.
On this next unit I have coming I'll hope it is starting from a better place than this one was which was clearly heavily molested before I got to it. If the impeller is filthy and broken like mine was on this one, I'd just clean carefully with alcohol and then just carefully super glue the cracked vanes and that is all.
I also noticed that the impeller was balanced as a motor/impeller assembly so by removing the impeller, it would likely only have compounded my vibration problems even discounting for the motor shaft side play. I marked mine in anticipation of this but the reality is that it was going to be a gamble if I could even assemble it with the fan clocked correctly had all the other bad not happened.
@Superhawk996
lol!!! sorry to hear about the impeller fiasco! i am not sure how you would take the motor out without breaking the fan.
i just got the new blower from Al and the fan is free and clear and spins smoothly.
just tested the static resistance and i get, 2.6 & 4.4 but on the high circuit 2.5 with motor hooked up. without motor in the circuit, it’s 2.8 low, 4.2 medium and 1.7 high,- looks like low and medium should be switched, i am sure i have the contacts located correctly.- also tested between each circuit, so those were
5.2 between low-medium posts( the 2 resistors combined?) 4.6 low-high, 2.8 medium-high, . do those number look better than the other fan?
