QUOTE(Chris914n6 @ Feb 8 2021, 06:47 PM)
FYI
Boxsters use 914 rear bearings, thus the compatibility I inferenced.
911 e-brakes bolt on with a welded on tab to secure the shoes. Not complicated.
The wheel well is like 10" deep. If you are hitting arm before inner you have a camber issue.
Camber is within spec; it was set when the PMB arms went in and more recently checked again.
The section width for Avon and Pirelli 215/60R15 tires is listed at 8.7-8.8", while a 225/50R16 Michelin Pilot Sport 4S is listed at 9", so I'd be thrilled if there was something like 10" to play with. My test fit suggested it's closer to 9".
Adding 911 e-brakes doesn't concern me, but I've seen complications with adding tabs for 911
calipers that led to brake squeal. The remedy was a do-over. Having watched a friend deal with that after a
good shop got it wrong, that is a consideration. 986 wheel carriers would eliminate that issue and make 986 four-piston Brembo calipers and drum-type parking brakes a bolt-on upgrade for a fraction of the price of 911 brakes plus 911 e-brakes, spot calipers, or RSR clamps. And unlike most caliper upgrades for the 914, which are 911 or 930 parts, 986 f/r calipers were sized and balanced for a mid-engined car. It's an idea worth exploring imo.
I think you are focused on a problem only you have because you want to run 80s 911/944 spec (and 80s tech) balloon tires.
215/60R15Avon CR6ZZ (vintage race/road rally available in three compounds)
Pirelli P6000 (N-spec summer)
Pirelli CN36 (N-spec w/period looks & modern technology)
215/55R15Michelin TB 15 VHC Racing Tyre (Dry / Wet, road legal)
225/50R15Pirelli P-Zero Trofeo R (R compound/summer)
Pirelli P Zero Asimmetrico (summer performance)
Pirelli Cinturato P7 N4 (period correct summer in modern construction/compound)
Toyo RA1 (R-compound track-day tire, retro looks)
Toyo R888R (R-compound track-day tire)
Yokohama Advan A052 (Extreme Performance Summer)
225/50R16Michelin Pilot Sport 4 (Ultra-High Performance summer, O.E. 991/992)
Michelin Pilot Sport A/S (Ultra high-performance All-Season)
Pirelli Cinturato P7 N4 (High Performance Summer)
Pirelli P-Zero Trofeo (ultra high performance Summer)
Bridgestone Potenza S007A (Extreme Performance Summer)
Bridgestone Potenza RE-71R (Ultra high performance Summer)
Continental ExtremeContact Sport (Ultra High Performance)
Toyo Proxes RA1 (R compound track day/race tire)
Yokohama Advan Neova AD08 R (ultra-high performance summer)
Many/most of these are at the cutting edge of current tire tech, and some allow staggered sizing with 185, 195, or 205 fronts—and there are other summer tires, all-seasons, and near slicks not listed here.
So this is less about "80s balloon tires" or the idea I'm alone in wanting more tire without big flares—as others have snuck 215s or 225s into narrow 914s to varying degrees of success or failure. This is about charting a path that
isn't going it alone and doesn't leave other 914 owners to do so. The keys to minimizing work on the outer fender (and all the ills it brings) appear to be wheel offset (15x7R or custom 16x7~) and inner fender/trailing arm clearance. My goal was to stoke discussion around a sensible, repeatable path to the best tires and brakes that will fit under a narrow 914 with the prospect of long availability for consumables. And maybe a trailing arm that offers benefits to any modified 914, including one with big flares.
"All" that's missing is an arm between the 914's pickup points and a pair of (modified?) 986 carriers. Can such an arm be reasonably engineered? I don't know, but I think it's a fair question to ask in a 914 forum…
