QUOTE(Chris914n6 @ Mar 12 2021, 07:27 PM)
Stock rear fender and why some tires don't fit well. Just over 9" of total tire space.
Driver side:
Pass side:
^ Yep, which explains why I was able to get a 215/60R15 on a 15x7R into both fenders with the car back on its weight.
Both the Avon CR6ZZ and Pirelli P6000 list a section width of 8.8 inches when mounted on a 7-inch wheel. But that tire is gonna need a little more room to "walk around" under load and with the suspension under compression. Question is how much? Or, rather, how much
more than 0.2 inch? Someone mentioned 5mm per side is enough (so 10mm total, or .39-inch), but I'm guessing it'll need to be more than that?
Michelin lists the new Pilot A/S 4 225/50R16 with a section width of 9 inches on a 7-inch wheel, which is closer than the 215/60R15 than I would have thought. Toyo RA1 and Pirelli Trofeo R list a section width of 9.2 inches. Yoko Advan A052 lists a section width of 9.1 inches on a 7-inch wheel—so the 225/50R16s would require a bigger stretch…but these are all great tires (as anyone who has tried the A/S 3 knows…and the rest are R-compound wonders).
I guess the question for those who have pulled rear fenders is: How much room have you snuck in back there without paint work? I am guessing not much…
