I've got a 71 914-4 that I converted to a 914-6.
The problem is a very loud annoying squeak when I'm in the R-1st plane.
Something is really scraping badly.
Pulled the shifter which looks to have been changed out from an early shifter to a later shifter.
Greased it very well and that didn't seem to help.
So I looked a bit deeper and put a flashlight in the tunnel where the shifter sits pointing backwards.
Using a small mirror about 6-9" rearward, I see that the shift rod goes through a circular opening in a small bulkhead that is welded into the tunnel.
Looks like the scraping/squeaking is when the rod is hitting the edge of the circular opening in the bulkhead in the R-1st plane.
If you don't pull the lever all the way to the left, then you don't hear the scrape.
Is this typical of a side shifter conversion for an early 914?
Am I shifting incorrectly by pulling the lever hard to the left for the R-1st plane?
Does that bulkhead need to be removed by opening up the shift tunnel from above?
Any thoughts or ideas are welcome.
Thanks in advance.
