Update on OEM mount
Got the engine side back from powder coat. Looks great!
Yesterday I received the URO mount p/n 914 375 049 00 Appears to be nicely made.
Did a quick trial fit to put URO mount into the body side bracket . . . almost!
Not a big deal really, but the body side bracket will need a little clearnace work to properly fit the the radius of the URO isolator can.
I want to be really clear - I don't see this as reflecting poorly on the Mad Dog mount or the URO isolator.
When you're doing these sorts of conversions with hand made parts, a little finessing is part of the game. Knowing many will likely use the Wevo mount, it wouldn't even be an issue. The isolator holes line up perfectly though! Great job making allowance for use of the OEM style isolator!
Likewise, there could be minor difference in the URO isolator can vs. the 914/6 mount isolator that Mad Dog built his orignal prototype to. Again, I'm just very glad URO is reproducing the 914/6 mount that was NLA for quite a while.
Mock ups and trial fitting are all part of the game. Just wanted to post my situation and prep others for need to do a little fitting to make it all work.
