Full Version: Been gone awhile
d914
I have been gone for a few years. Transferred back and forth, ATL-OKC-ATL.
4 years in OKC, then a year on the road and then a year off working on fixing up the old homestead ,selling and then buying all over again.
Covid shut us in and somewhere along the line I gathered up my car, put back in my garage and stared at it for awhile.
Then brillance struck!!!! ?????? %^^&&$%^$^%^&%
Pull out the Suby turbo and start over!! Of course... Brillant.
Exorcised the ghosts, fresh plan, new parts, Blank slate.
Found a 4.8l truck motor cheap and rebuilt and customized for 914.
Found a boxster 6 speed and adapter set up here. ValcoOscar, Thank you.
BigKat filled in the blanks with 930 axles..
We have the tech, we can reebuild!!!!
greg d914
d914
the engine and tranny.
4.8 l ls motor
holly intake, 4150 throttle body
swap oil pan
ict billet pulley sys for corvette
corvette water pump
renegade tranny mount
d914
cleaned out 6 years of dirt and repainted
went back to full dash
boxster shifter future tense
cleaned up a lot of so so work that i did before.
d914
d914
the starting point
d914
under construction
good to be back and playing again.. the car is close, i can work for hrs or just minutes.. feels good.
bkrantz
Cool. Not subtle, but cool.
d914
Subtle left the barn years ago!
Root_Werks
d914
inner longs done
rear console from Tangerine Racing
reinforce suspension ears
raised spindles tangerine racing
elephant racing bearing on swing arm
mono ball on front struts and rear shocks
Delrin bushing from Tangerine
swing arm brackets from tangerine
Wilwood brakes front/911 rear
911 sway bar
for the street, c4 red leather buckets, three point set up.
oh and added a cam to the motor, sloppy 2/ with springs and upgraded rockers
Holly intake, fuel rails and throttle body
d914
was going to go stock ecu and picked up a Wire Harness from Ebay.. Chinese but looks good.
Decided to go Holley terminator X for ECU and Harness. Hand Held and self tuning. These days faster and easier is better!!!
Harness will be going up in parts section if not sold locally. First come first serve. Was $240..... call it $200
Other wise making room for the engine, shifter cables and lots of little stuff. Need to take apart engine and tranny to install tranny pins and tighten up all the conversion plate bolts.
Root_Werks
From what little I can see in the pics, looks like you have a great platform for such a build.
Only ever driven one V8 914 and I liked it. The rumble of 8cyls behind you was pretty cool.
DRPHIL914
welcome.png well that is welcome back! i am subscribed!
missed your first reposts a few weeks back but looking forward to seeing this go in. Bob(Bigkat) has an awesome V8 LS conversion as well , so i am sure he can advise you on the journey. that’s going to be scary with almost 500hp wow!!
d914
QUOTE(DRPHIL914 @ Apr 27 2021, 04:38 PM) *
Bigkat is a co conspirator! His car is scary fast
d914
Killed off jack stands and built these
d914
d914
d914
Killed off jack stands and built these. ( sorry for the dups... internet was going crazy and haven figured out how to delete.
d914
Engine in place
d914
I'm now going through the wiring I had to cut and figure out what wasnt finished from 5yrs ago!!!
d914
d914
Digidash for my dash
d914
a wiring I will go!! Slowly but surely finishing all the wiring. Added new fog lamps, hella horns for a little protection and Firewall grommets to help with routing. I also need to cover up that hole. That was from my previous tranny!
krazykonrad
Where in Atlanta are you?
d914
riverdale down by the airport... need any parts??? going to have a garage sale soon.. its a pay forward kind of thing
d914
Making sausage! Arranging computer,relays and such as neat and efficient as possible. Making headway. Can't really finish until I fix that hole first.
d914
Cleaned and small re-design. Finished for now waiting final connections.
dakotaewing
Questions...:
What mirrors are on the doors?
What clutch / flywheel / pressure plate are you using? (Please be very specific)
Thanks!
d914
QUOTE(dakotaewing @ Mar 10 2022, 10:34 PM) *
Questions...:
delta 88 or park ave mid 80's gm1320138
dont really know. Adapter plates, clutch and fly wheel came with the tranny
Thanks!
d914
setting up dash.. added in the hand held for the Terminator-x.
The race is on. Retiring in June. It used to be joke on which got here first. Finish the car or retire!!!
d914
Using some old corvette seats for on the road, Comfy and a bit of flash. Test fitting some things
d914
dash set up
d914
old has t go.. Too warped
d914
Fleshing out new one. Gas door, riveted louver this time( newer design) flush fit hood pins.
d914
upgraded boxster shifter to ball bearing unit from uniwerks.
d914
new hood with gas door and louvers
Gearup
Ooooh. That looks like one of Bob’s engine mounts . I been begging/bothering my poor friend for one for a while:)
d914
on the ground for a bit , final debugging new wiring. starting on the exhaust and final brake work.
d914
gratuitous shots and playing w patina for a bit.
mgp4591
[quote name='d914' date='Mar 2 2022, 05:58 PM' post='2985329']
d914
two forward one back!! Car almost ready to go to tuners.
-replace brake switch and wire
- residual valve for clutch
- resolve shifting issue, might be the cable
- trouble shoot blinkers after led upgrade.. might be a fuse.
- a couple of nuts an bolts
A bit slow these days messed up left hand with a circular saw.. lost part of thumb and working on getting fingers working again.. can you say dumb ass moment!!
upgraded to full led lights.... fronts by 3dgauto!
d914
do to my recent mishap, son, came up for a name for the garage... kids you gotta love em
andys
QUOTE(d914 @ Jan 16 2024, 10:07 AM) *
Nice build! With Bigkat as a co-conspirator, you're in good hands.
Can you please share the source for the hood vent; i.e. source, part number, steel or aluminum?
Thanks,
Andys
FL000
Maybe I missed it, but what were your decision factors for pulling out the Subaru and going with the V8?
d914
QUOTE(andys @ Jan 16 2024, 02:08 PM) *
Thanks,
Andys
https://racelouvers.com/center-hood-louver-...-rt-track-trim/
d914
QUOTE(FL000 @ Jan 16 2024, 03:37 PM) *
it sat for 4-5 years while I got relo'd and I had some kind of issue making it not run right.
Turbo piping, intercooler water system and that bug.. We had done ls swaps to my truck and bob's 914.. overall it was a known and I ran out of patience. bought a new house, moved the car in threw out the old and moved on. I stilllike the suby and the lighter weight... fickle!!!
rhodyguy
The patina is awesome. Take care of your fingers. They cannot be replaced. How many were damaged?
d914
QUOTE(rhodyguy @ Jan 17 2024, 02:15 PM) *
lost part of thumb due to lack of blood flow. got all the ligaments and nerves.. slowly getting movement and feeling back.. goal is to be able to hold a golf club or my steering wheel so i can still shift. Sometimes it looks like I have tourettes as the nerves intermittently fire.. brief flash of pain... grocery shopping always fun as people look at me a bit strange!!! smile.gif
Invision Power Board © 2001-2024 Invision Power Services, Inc.
