redshift
Jul 22 2005, 03:51 PM
QUOTE (Headrage @ Jul 22 2005, 05:49 PM) |
Hmmm? |
YES ALLAN!
M
bondo
Jul 22 2005, 03:52 PM
QUOTE (Headrage @ Jul 22 2005, 02:45 PM) |
Will the tranny fit in a teener? |
Yup, Chris Julian's V8 has one. Not the cheapest route by far.
Allan
Jul 22 2005, 03:54 PM
QUOTE (redshift @ Jul 22 2005, 02:51 PM) |
QUOTE (Headrage @ Jul 22 2005, 05:49 PM) | Hmmm? |
YES ALLAN!
M |
$6300.00
redshift
Jul 22 2005, 04:29 PM
I think I saw it somwhere that Bruce sent me a couple weeks ago.. not rebuilt, out for a 6 speed upgrade? 42k or some such?
Not a bad deal, not the best, but not bad. I have seen similar, unpolished ones for.. around half that.. but out of salvage, or just sitting.. so.. you know how that goes.
M
neo914-6
Jul 22 2005, 04:37 PM
QUOTE (redshift @ Jul 22 2005, 02:29 PM) |
M |
RBT:
New ZF 5-speed is $8800.00
Rebuilds start at $1200.00
New 6-speed is $15,000
redshift
Jul 22 2005, 04:54 PM
Yeah, new is not expensive, or cheap, depending on how you look at it.
Most important thing is like all auto related thingys, service history, and updates.
M
jd74914
Jul 22 2005, 06:39 PM
Panteras are nice. A friend of mine's uncle took me for a ride and lit up his tires at 80. I like
LS6/914
Jul 22 2005, 09:14 PM
Worked late 70s early 80s at a shop that serviced Panteras. The 351 C is bullet proof and is considered a small block. The heads have huge flow potential. Check the front corner of the head at the valve cover for a cast "4" or four dots. designating the larger valve heads. The half shafts use u-joints and are readily available. To check timing or service the water pump or belts requires removing the passenger seat and dissassembling the firewall. The Pantera was prone to A/C failures, overheating, rust, no headroom..... however a ape could get a date in this car. When alls said and done Iam still a freak for a 914 with a stout V8.
9144guy
Jul 22 2005, 09:24 PM
i worked on this 73' last month
9144guy
Jul 22 2005, 09:28 PM
guess that pic. was cut short , another
