@JeffBowlsby below is about as far as i can take the logic for the three number series of engine stamps past 72.
first of all i looked at your engine stickers and markings section on your website.
i liked the way you posted them chronological.
to try and tease out an order?
https://bowlsby.net/914/Classic/PLM.htmi thought ok. there is something there.
the weird thing that jumps out is the EA EB series engines.
in between the numbers for the EC engines and the G series engines.
whats that about?
and then it goes from 6 as the first number for 73/74 to 9 as the first number 75/76.
its kind of chronological set of numbers and kind of not.
i'd found random engine stamp numbers in research for EC engines along the way.
for different model VWs.
this is what i found.
VW type 1 engines. (beetles) with upright fan shroud.
all seemed to start with 1 as first number of three digits.
(i found a thing with the same number, has the same engine, but might not have been an original engine as i think things basically take a beetle engine straight up).
Click to view attachment Click to view attachment i came across a bus engine, for buses fitted with type 1 engine.
has a 2 as a first number of three digits.
Click to view attachment found a 73 type 3 engine. (last year of type 3 production).
has a 4 as first number.
Click to view attachment found a type 4 engine. 74 412 with L jet.
has a 5 as a first number.
Click to view attachment ----------
then found something interesting.
75 bus with a type 4 engine.
has a 7 as the first number.
Click to view attachment couple of 78 buses with a type 4 engine.
has a 4 as the first number.
(thought, wait a minute, type 3 had 4 in 73 .....but that was it for type 3 as ceased production in 73).
Click to view attachmentClick to view attachment so maybe buses with type 4 motor got reallocated the 4 number post 75 or something like that?
...........and is this a bit like 914 goes from 6 to 9 in 75 as the first number.
and that 6 that is in front of the 73/74 model engine stamp numbers links with the 6 that comes after 022 in the 70-72 cars. so 6 stays with 914s from 70-74 in terms of production identification for the engines being made in hamburg.
thats the point in thinking where i thought, ok the first number represents the model the engine is going in.
but the number does not stay stable. it gets reallocated in periodic adjustments of the model allocation number as VW cease production of certain models and introduce new models. there is quite a bit of that going on in the period 73-77 as VW overhaul their range and introduce the new water cooled engine cars to replace the air cooled cars.
then i took another look at the 914 numbers and arranged them slightly differently to your chronological list of markings down the page.
i used the numbers instead arrranged in ascending order down the page.
i got this as a rough worksheet. and thats all it is. a rough worksheet.
Click to view attachment the black ones are the ones we know exist.
the red ones are the gaps in the numbers.
they could be real or they could not exist.
there are quite a few variations of the 914 engine unaccounted for.
particularly the european variants of the motor.
one way to flesh out this speculative list is to canvas member owners of 1975 1.8s.
those numbers can be obtained from resources available to this website.
they are hard to see hidden under the heater blower fan hose so members need to look and uncover them. not something you can glean from BAT ads.
as to euro 1.8s. the only one probably is that one in the porsche museum.
they may be able to oblige?
i think the EA numbers work the following way.
EA370 covers the development order to do the post 72 engine range.
its probably an order supplied to porsche.
then there is the mysterious EA 349 development order.
this is matched to a 621 G series engine.
Click to view attachment you need a full list of the VW EA projects with the dates to get to the bottom of that.
i think what happens in a very approximate way is.
initially the program for replacement engine range (post 72) gets laid out.
all the numbers are allocated.
they already know before 1972 what they have to do and they know the steps ahead in relation to US EPA and CARB laws and the years in which the steps will occur.
1. unleaded gas.
2. lowered NOx CO HC emissions.
3. introduction of cats.
so the set of two final numbers of the three get allocated/listed.
initially it would have all been laid out under the assumption of 6 as the first number.
the 6 gets changed to 9 in 75 because VW do a reshuffle on the model number the engine is going into as they rearrange their model range?
thats as far as i can take it.
but it is within the means of this website and members to flesh out the 9 series of numbers for the 75 1.8s and fill in a few more gaps.
and i have made my deadline to get all of this out of my files and on to the website here before the end of the year so i can go do something useful in 2020.
happy new year for 12 hours away now here. we are on the other side of the dateline.
