QUOTE(Van B @ Nov 20 2021, 09:08 PM)
Well, emissions sticker is there… its also gone forever. It was sprayed over when new with corrosion protection. So, not likely it would survive any attempt to reveal it.
Engine number is EC008741, but that’s the best I got. Other than it’s a US spec with the low compression pistons that provide a whopping 76hp/91ft lbs… to the crank.
sounds like an owner/dealer that knew about the dreaded battery/hell hole corrosion problem even in 1974 and did some proactive work!?
never mind.
there is one more thing you can look for when you get a moment.
these engines get white stamped numbers on their tin ware.
the number ought to still be there with a bit of luck.
if you look down on lhs side of engine between the air cleaner and the heater fan you might be able to see it. might be either 604 or 605. or it could be some other number.
its down near the snap in cover for the alternator adjustment hole.
there is a chance its on the right hand side of the tin near the battery. but more likely its on the left hand side.
there is one other thing you can look for which is the little white tuning sticker.
usually on tin on top of engine on left hand side. it might not be there any more.
fairly fragile. if it is there take a snap of it and post it up.
thanks for all the info so far. its fairly useful. trying to work out why there was an EC-A engine that had california and 49 states and then there was also an EC-B engine with the same. starbear and i have the EC-B one.
and then there is also an EC-B which had only 49 state. its fairly weird what was going on. we are trying to work out what the differences were. don't think we can ever work out the why!
yeah - the horsepower from these engines is frightening.
i took mine out for a run this morning. hit the streets early before the post lockdown zombies got on the roads. went for a run down by the docks and opened her up.
acceleration almost made my head move but maybe it was the gear changes.
i'm trying out one more theory with mine which is the gas might have gone off.
we have been restricted/locked down here so i've basically had 3/4 of a tank of gas in it for the last 4-5 months i've slowly used (i've lost track of time!) and i am wondering whether the octane has dropped. it can happen.
i will see what a cold start next weekend is like on some topped up fresh gas?
