its way dumber than that
@Emerygt350 .
you can adjust things after the engine is warm.
the CO screw does all that.
and you could additionally measure O levels with a probe.
but......may not help for the warm up.
from what i have read the warm up enrichment is controlled by 3 things.
1. CHT. Van has already put in a new one.
2. intake air temp sensor in AFM.
3. movement of the stator flap in the AFM (which would be drawn slightly open by the AAV being open).
#2 influences and modifies the signal sent by #3 to the ECU. so that intake air temp sensor has an effect on the signal generated by the stator flap and the ECU can recognise the engine is cold and even further to that it is drawing in cold air. logic tells me that is what sends it into the cold start regime. part of the input is the CHT. but there is also input to say stator flap is slightly open (AAV pulls it open but as a piece of "clockwork"). and the ECU recognises those two additional inputs, stator flap and cold intake air. ie it can also distinguish that the stator flap is open in a cold air situation. together all three switch a circuit(s)in the ECU that is the full cold start regime?
how you can adjust that alone is i think not possible.
you can adjust CO at warm idle and you can adjust CO generally i think at ECU further.
i'd have to check up on our ECUs for 1.8s again. but that is not going to help at warm up as its got an internal "routine" so to speak inbuilt in the ECU if you could call it that.
so i think an air temp sensor in AFM or the printed circuit the stator flap sweeps over could be a culprit. it would be in that section of the first part of the stator flaps movement. the open AAV would not be pulling the stator flap very far open at warm up.
but if its not getting the correct electrical signal generated by that first part of the AAV flap movement it is definitely going to affect enrichment. it might be worn or have residue built up on it.
there is some proceedure to clean that printed circuit in there.
i've come across it here on this website.
how to open up the AFM and do that.
as to the temp sensor in there.
somewhere i have an L jet tech manual that tells you how to test it.
but.....having said that it then says that if it is defective it cannot be repaired.
however - as we know 914 owners seem to be capable of rebuilding just about anything at this stage that previously were regarded as unfixable and to be thrown away.
down at the workshop i can get hold of an exhaust gas analyser.
a real old piece of equipment. we use it to tune all the old cars.
but there is something that needs fixing on it at present.
we have been borrowing one from the mechanics across the road.
i'd have to leave the 14 down there overnight and then do a cold start fire up.
i think that would give me the values you are talking about emery?
whats going on at cold start in terms of the air fuel ratio.
i've got a good CHT i have tested.
i've got good injectors that work perfectly.
i've got a good cold start injector and temp switch that works perfectly.
i've got an AAR that opens but i suspect may close too quick.
and a similar set of symptoms to vans car at cold start.
and a similar set of components i know to be close to as good as the ones van has in now.
(i'm guessing if i was in maryland or cold cold north america mine would really fall in a deep hole too for the first couple of minutes just like vans).
and i'm think with mine when i get it into the workshop for the fuel pump fiddle that i will see if i can do the tests on the AFR and maybe even open it up and clean it if necessary.
i can test the temp sensor too, but what i can do about it i don't know if its not right.
