Thanks for setting up the drive Troy, it was awesome! Sorry Michelle and I couldn't stay with the group longer. I bumped the timing up a little more and still no pinging or hot temps. Although now that the engine has some miles on it, a valve adjustment is in order. It was really nice seeing some friends and meeting some new freinds.
Looking forward to seeing the guys who are coming to Whistler. I changed out the dashes, gauges, gauge panel, carpet and such yesterday. Looks much nicer now. Still need to do the door panels though. I thought I was using as much as half throttle to keep up with you guys from time to time. Or if I ever stuffed it, I would pause a few seconds between shifts to keep a distance. Turns out the plastic gas pedal screw was all the way out in adjustment. I just pulled it out yesterday, checked carb shaft travel. Cool, full throttle now, it was like an extra 30hp!
